04-23-2023
10:20
09:04
AndreaFitbit
04-23-2023
10:20
09:04
AndreaFitbit
The app works too and sleep patterns and blood oxygen levels are still being monitored.
Any ideas please?
Moderator Edit: updated subject for clarity.
05-03-2023 04:31
05-03-2023 04:31
Hi, @Tourer4304 , check the brightness setting on your Charge 3. It may have accidentally been set to dim. It is under the settings menu on the watch itself.
05-05-2023 10:07
05-05-2023 10:07
Best Answer05-08-2023 01:51
05-08-2023 01:51
There seems to be a common problem where the display on the Charge 3 stops working. Some people (including me) have found that restarting fixes this: Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger
Regards,
Will
Best Answer05-12-2023 00:08
05-12-2023 00:08
