05-18-2020
09:51
08:52
05-18-2020
09:51
08:52
My screen started not working properly yesterday morning. It started with white lines through the step count, heart rate, etc. but I could still see the time. This morning, it was stuck on last night’s time. I tried a short reset and the entire screen became unreadable. So I changed the clock face, did a long reset, and deleted and re-downloaded the app. I’m back to where I started...step count, etc. barely readable with white lines through it, and I can see the time. How do I fix the issue completely? Thanks!
05-18-2020 10:19
05-18-2020 10:19
@becoming16 Hello! Since it looks like you've already troubleshooted the device, I'd recommend you reach out to Customer Support for further guidance. Best of luck!
05-18-2020 10:19
05-18-2020 10:19
06-16-2020 10:55
06-16-2020 10:55
Did you get the problem sorted? Mines just started with the same issue
06-16-2020 11:11
06-16-2020 11:11
I was never able to fix it with the normal troubleshooting steps. I reached out to customer service via chat and they were very helpful. Before doing the same, try all of the troubleshooting (short and long reset, changing clockface, deleting and redownloading the app) because they'll ask you to verify that you've tried everything. I hope this helps!
07-02-2020 12:26
07-02-2020 12:26
But did you get it sorted as mines now doing the same and I have tried many things to fix
07-02-2020 12:52
07-02-2020 12:52
Yes, once I exhausted all of the options on my own, customer service helped me to get a replacement.
