07-24-2022
04:32
07:35
AndreaFitbit
07-24-2022
04:32
07:35
AndreaFitbit
08-04-2022 06:20
08-04-2022 06:20
Thanks for getting back to us and for letting us know about the steps you have followed in order to make your Charge 3 screen work properly @dwrunner.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Keep on visiting the forums.
07-24-2022 04:33
07-24-2022 04:33
Moving this to the Charge 3 forum
Helen | Western Australia
07-28-2022 07:51
07-28-2022 07:51
Welcome to the Fitbit Community, @Decodance. I'm sorry to hear your Charge 3 is too dark to read.
Please check that your tracker is not in Do not disturb or Sleep mode. If this wasn't the case please try restarting your device:
Open the Settings app on your device and tap About > Reboot Device.
If your tracker is unresponsive:
Thank you for your assistance @NellyG.
07-28-2022 10:13
07-28-2022 10:13
There doesn’t seem to be an “About” option under Settings. How do I access that?
07-28-2022 11:28
07-28-2022 11:28
Welcome to the Fitbit Community, @JULIEACA. Thank you for sharing your question in order to access to About option on your Charge 3 settings.
You can try setting up your tracker as a replacement device and see if you find this option.
You can also follow the recommended steps after the step you can´t follow.
07-28-2022 12:42
07-28-2022 12:42
Is there any way to reboot when away from home/ my computer??
07-29-2022 06:25
07-29-2022 06:25
Welcome to the Fitbit Community and thank you for your question @nontrad.
You can plug the charging cable into the USB port on any UL-certified USB wall charger follow the instructions.
I hope this information helps.
07-29-2022 08:25
07-29-2022 08:25
Thanks. Followed all the instructions and advice, but screen has simply dimmed over time
07-29-2022 08:42
07-29-2022 08:42
Thanks for getting back to us and for following advised troubleshooting steps @JULIEACA.
You can also try a long restart:
07-29-2022 17:10
07-29-2022 17:10
I have done everything suggested here - no use as I can now see nothing on my screen. I am thinking my journey with Fitbit is now coming to and end.
07-29-2022
17:56
07:06
AndreaFitbit
07-29-2022
17:56
07:06
AndreaFitbit
how disappointing! They must have designed it to not last long. What a shame
Moderator edit: format.
07-30-2022 18:57
07-30-2022 18:57
I have had my charge 3 replaced twice in 3 years. All with screen problems. None of the given solutions work. I can no longer read the screen. I read the information from the app.. don't know what to replace it with. Think is is designed short lifetime. Disappointing.
Any suggestions?
08-02-2022 07:14
08-02-2022 07:14
Welcome to the Fitbit Community, @leigha2 and thanks for getting back to @JULIEACA, @Sandra30000. Thank you for your comments and I know how frustrating this could be.
Please try changing your tracker's clock face with the steps of: How do I change the clock face on my Fitbit device?
08-03-2022 19:22
08-03-2022 19:22
My screen can no longer be seen in daylight. I have rebooted and changed clock face to no avail. Part 2 is that my steps do not reset at midnight starting 2 days ago. I am now at 60,000 steps today. That's with a nap and an hour reading a book.
08-04-2022 06:20
08-04-2022 06:20
11-10-2022 00:41
11-10-2022 00:41
Just go to settings/brightness and select brightness you want Dim/Normal/Auto. It defaults to dim.
Regards,
Will
11-10-2022 03:32
11-10-2022 03:32
11-10-2022 03:59
11-10-2022 03:59
11-10-2022 07:13
11-10-2022 07:13
Trust me, I tried that about 20 times. It just was like the screen backlight was losing power.
11-10-2022 07:52
11-10-2022 07:52
I think it is losing power. Dying…
