12-06-2020
09:36
11:08
AlvaroFitbit
12-06-2020
09:36
11:08
AlvaroFitbit
The screen on my Charge 3 is almost impossible to see in bright light (sunlight or bright indoor light) even when set to "normal."
It is fully charged and undamaged.
This has only been an issue for the last month or two, so assume it is either a hardware or software issue. The "normal" setting used to be significantly brighter and easier to see.
Is there a patch coming to make our screens brighter, or is this a tactic Fitbit is using to try and force people to upgrade to the Charge 4 if they want to actually be able to read their screens?
12-06-2020
11:10
06:59
12-06-2020
11:10
06:59
@SunsetRunner Welcome to the Community.
Sorry to hear that your Charge 3 screen is too dim. I suggest you check if the tracker isn't in the Sleep mode by long pressing the button. Additionally try restarting by following these instructions.
Let me know how it goes.
Best Answer12-06-2020 11:27
12-06-2020 11:27
I have already done multiple restarts. The screen is still barely readable on "normal" mode. It is clear that either the device is damaged, or a software change has made the "normal" setting dimmer than it used to be.
With the number of people who have had the same issue, it seems more likely that it is software-related and it is puzzling why Fitbit has done nothing to address this with a patch.
12-06-2020 13:35
12-06-2020 13:35
My FitBit seems to have put itself in sleep mode automatically. I wasn’t even aware of this mode before I started having the dim screen problem this morning.
Best Answer12-06-2020 13:39
12-06-2020 13:39
Sleep mode is not an issue for mine. It is too dim to read in bright light regardless of whether it is on Sleep or not.
It shouldn't be too hard to create a software patch that restores "normal" to its former level or creates a "bright" setting. But I think Fitbit would rather not fix it and hope we buy a newer model.
12-06-2020 14:19
12-06-2020 14:19
Hi I have the same problem. I try to restart several times and doesn’t work. Any problem with the software?
10:21
06:58
12-08-2020
10:21
06:58
@LinnLaure @LucreciaV @SunsetRunner I hope you are doing fine.
@SunsetRunner @LucreciaV thank you for troubleshooting this issue. I have created a ticket so our Support team can further assist you via email.
@LinnLaure happy to hear that you were able to fix your issue following the suggestions in this thread.
Keep me posted.
Best Answer12-17-2020 02:41
12-17-2020 02:41
I wanted to thank everybody for your support and customer service! I'm very happy to be part of this family!!!
Have a wonderful holiday season and please keep fit and safe!
XX
12-17-2020
05:25
06:58
12-17-2020
05:25
06:58
Hi @LucreciaV, you are very welcome and we are happy to have you in our Fitbit family.
As a side note, I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often and have a happy holiday season too! 😀
