Charge 3 screen too dim
ANSWERED
My Charge 3 screen is excessively dim, even with a full charge.  I've tried restarting it with no result. It will occasionally come on bright but after a few seconds it's dim again and I can't get it back. This is indoors and is still difficult to read. Outside with any amount of sunlight, it's impossible to read.
541 REPLIES 541
Yes. However I can’t use it as I can’t see anything. So useless for telling the time or recording any form of exercise. Not fit for purpose!
Sent from my iPhone
I saved mine but got the Apple Watch. I love it so far. Still learning the features on it. Kept my Charge 3 in case they decide to step it up and take responsibility for their ways...
Sent from my iPhone
For months my Fitbit has been too dim to read. At first I thought it was because I wear prescription polarized sunglasses often or that my regular glasses needed a stronger prescription or that I needed to adjust the brightness settings. After finally sitting down to troubleshoot it it was obvious the problem was with the watch itself.  I called support and after an hour on the phone thankfully I was able to get them to send me a replacement. Comparing my old Charge 3 to the new one I am shocked at the difference in screen brightness. I can’t believe Fitbit is not recalling and replacing everyone’s watch that has this issue. Clearly this is impacting many many users. https://imgur.com/cDqqetU
note: new watch looks bigger because it has the band. When they sent a replacement it was just the watch itself.
Has your new charge 3 been ok and you’ve had no further problems??
Sent from my iPhone
I cannot believe that Fitbit refuses make this right with all the people that it effects. I guess they have more customers than they need.
I’ve only had it for a few hours but I did update the firmware to the latest version and it’s 🤞still really bright. Seeing how bright the new one is I’m absolutely shocked at how dim/hard to see my Old one was. Even on the “dim” setting it’s still brighter than the old one. To get my replacement I was on the phone for an hour and escalated to a manager. Do not use the Chat support because if they give you an offer/coupon for a discount on a replacement then that closes your case and supposedly the phone reps can’t override. So definitely call instead.
Thanks for the advice, I had the same issue with Charge, which was
replaced. It is a shame that this product has a relatively short lifespan.
I do really like how it works, although it failed to track my sleep pattern
last night for the first time, I guess it may be on its way out all
together.
No. It is two years old and they won’t replace it.
So far it is okay. I hope it lasts more than two years!
Sent from my iPad
Just out of curiosity, if the Charge 3 was released in October 2018, how is yours 2 years old?
Mine is only a year old
Sent from my iPhone
No resolution, just the typical "we are working on it lame excuse"
Mine lasted 7 months before developing this problem. Guess what they said
warranty was ...... Six !
Mine is toast also.
Only way I knew it was working was because I could feel it vibrate. Can only read it inside when it is set to normal.
Mine went from dim to know display and this is the second Charge3 I have had in less than one year. The first device froze within four months.  Replacement sent and lasted about 5 months screen developed lines and then went black this am. It is still tracking but I can’t set workout activity. It never picks up my workout activity after 10 minutes either, ever!  I am deeply disappointed in this product. For the cost it should not behave this way on two separate devices. What gives here?
It’s my understanding if they replace your Fitbit under warranty, the replacement is also under warranty. You should definitely call the support number to complain!
I called the Support line 2x and all they said is they can’t replace it due to the on going problem. And second, I just need to wait for the fix. Now it’s out of warranty and I guess it doesn’t matter that it stopped working over three months ago. My loss apparently. Love my new Apple Watch though. ♥️
Sent from my iPhone
Thank you. I am working with Support. The instructions they sent did not work. I will continue to advise as I progress through the process.
Scott
Sent from my iPad
Don’t expect much Scott! They’re basically useless...
Sent from my iPhone
I am curious what device you would switch to. I have started researching and I find myself considering the Apple Watch, but I’m really open to something new or innovative that might not yet have broken through. Thoughts?
Sent from my iPad
