10-18-2020
09:01
06:18
JuanJoFitbit
10-18-2020
09:01
06:18
JuanJoFitbit
Hey guys so I've got that lame black screen thing going on, and none of the standard suggestions work. Resetting it with the button, updating the clockface. It can't even get it to resync with my app because I can't see the numbers. Can't seem to find a way to hard factory restard without being able to see anything, I think if i was able to reinstall the firmware it might help but how?
10-19-2020 06:17
10-19-2020 06:17
Hi @Baileyssinger, welcome to our Fitbit Community. I'm sorry to hear that the screen of your Charge 3 went black and it won't turn on. I totally understand how you feel about this and I appreciate the time spent trying to get this issue resolved.
I'd like you to try a long restart, which has been helpful for this type of issues. To do so on your device, follow the steps below:
Keep me posted on the outcome.
10-19-2020 08:11
10-19-2020 08:11
I'm having same issue. Black screen. Vibrates and charges but won't sync with phone. Clock reset didn't work. Short reset didn't work. Long reset didn't work. Can't factory reset with black screen that won't sync. Anything at all I can do?
10-19-2020 10:14
10-19-2020 10:14
It sounds like the same issue I'm having, I've posted it as another issue
10-19-2020 17:45 - edited 10-19-2020 17:49
Hey thanks for responding. I've tried the long reset. I do experience the vibrations, but I can only seem to get 4 short vibrations before it stops, and the screen never resets
10-19-2020 17:55
10-19-2020 17:55
Same for me. I got up to 6 vibrations and it stopped before the 7th and never resets. Ugh. I've tried so many times!
10-19-2020 18:02
10-19-2020 18:02
Good evening,
I'm experiencing the same issue where the display is a black screen. My app indicates the battery is full, I've changed the clock face over dove times with no change to the black display.
I've also done the aforementioned reboot, I can feel the vibrations but the screen still has no change. My wife also has a Charge 3 that is functioning properly (we bought them at the same time), and we've used her charger as well with no success.
10-19-2020 18:03
10-19-2020 18:03
Apologies for the typo, we changed the screen display over five times. Not dove times.
10-19-2020 18:54
10-19-2020 18:54
Same thing exactly for me. Let’s get this solved fitbit
10-19-2020 18:58
10-19-2020 18:58
Same problem here. Regular restart, long restart, clock face reset all do nothing -- screen remains black. Is this a firmware issue?
