10-13-2018
16:21
15:06
10-13-2018
16:21
15:06
Got this yesterday and the screen is already black and won’t turn on. Very very disappointed, looks like it’s a common issue. I’d rethink getting this, a shame it’s so common for the anticipation of this...
03-03-2019 06:27
03-03-2019 06:27
Put on charger and pressed the button. Reset and worked. Excellent community tip.
03-03-2019
06:48
05:51
YojanaFitbit
03-03-2019
06:48
05:51
YojanaFitbit
You can call fitbit and they will mail you a new one. Or you can cut your losses and get a different watch altogether. The charge 3 is the worst I’ve had, and I’ve been using fitbit watches since they came out.
Good choice. Mine was broken. They replaced it.
03-03-2019 07:50
03-03-2019 07:50
My FitBit is black. It was on the charger all night and is still black. I have pressed the side button and nothing happens. What do I do?
03-03-2019 09:40
03-03-2019 09:40
Plug it in and then push the button for at least 8 seconds.
03-03-2019 09:43
03-03-2019 09:43
03-03-2019 23:11
03-03-2019 23:11
How do you pres the sides of its in the charging cradle?
03-04-2019 02:12
03-04-2019 02:12
I was able to use the tip of my index finger.
03-04-2019 02:55
03-04-2019 02:55
This worked for me thanks.
03-04-2019 03:20
03-04-2019 03:20
03-04-2019
05:11
11:48
03-04-2019
05:11
11:48
It worked on the third try - thanks !
Moderator edit: removed personal information
03-04-2019 22:13
03-04-2019 22:13
Thanks for the tip as it fixed my screen.
Mel
03-05-2019 11:46
03-05-2019 11:46
My charge 3 hung on notifications screen then went black. I could feel if responding when pressing the button but screen stayed black. From the app on my android i tried sending a different clockface down to it and bingo....it came back to life. Might be worth a try for others experiencing this hang.
03-06-2019 04:54
03-06-2019 04:54
Mine still won’t display. It syncs to my phone but display is black. I can’t get it to restart.
03-07-2019 05:47
03-07-2019 05:47
What should I do if I removed the Charge 3 from the Fitbit app? I cannot change the clock and I cannot pair it if the screen is blank.
03-07-2019 14:28
03-07-2019 14:28
Hi Jogger, I was lucky as I bought mine from a local store. I took it back in after trying various tips suggested on here, that did not work. I explained the problem and they replaced it as well as giving me a new two year guarantee.
Rowli from little Wales 🙂
03-07-2019 15:08
03-07-2019 15:08
My screen went blank too... I took it off and charged it for about 30 min (it was only down to 80 percent bat). Now it vibrates when I push the button but it doesn't light up. Tried restarting again, it vibrates but well after 8 seconds and it didn't restart. Really bummed out!!
03-07-2019 16:00
03-07-2019 16:00
03-07-2019 17:37
03-07-2019 17:37
Thank you ! It worked 😊
03-07-2019 18:43
03-07-2019 18:43
03-10-2019 01:57
03-10-2019 01:57
Hi thanks for the tip. Smiley face worked for me x
