10-13-2018
		16:21
		15:06
		10-13-2018
		16:21
		15:06
Got this yesterday and the screen is already black and won’t turn on. Very very disappointed, looks like it’s a common issue. I’d rethink getting this, a shame it’s so common for the anticipation of this...
02-26-2019 16:38
02-26-2019 16:38
Didn't help. Very frustrated.
 Best Answer02-27-2019 04:15
02-27-2019 04:15
Charge 3 screen went blank yesterday and only a month old. I had to return my first one because it would not charge. I synced it this morning and it shows my steps and my sleep, but still blank. I have tried putting in in the charger and holding the “button, actually pressing the side, as no button on the Charge 3. Vibrates a couple of times but no screen. What is next? Return it for the SECOND time?
 Best Answer02-27-2019 04:43
02-27-2019 04:43
 Best Answer02-27-2019 12:32
02-27-2019 12:32
The fix helped me get my screen back but it seems o be a fairly common problem. I was lucky it happened in the morning before I left for work. Would hate for it to have been after I left and had no screen all day.
 Best Answer02-27-2019 13:28
02-27-2019 13:28
After about 6 months of use, my Charge 3 stopped charging. Got a replacement about an hour ago. Synced it, then the screen went blank. Fitbit is now sending *another* replacement, this time "overnight," which really means two days (waited a WEEK for the first replacement).
If this second replacement fails, I'm moving on to another brand. I loved my Charge 2; not willing to deal with the ongoing glitches of the Charge 3 beyond this. Fitbit has been pretty solid on the customer service, though the incredulous person I talked to today seemed to question a *second* failure at first. You and me both, lady.
 Best Answer02-28-2019 02:02
02-28-2019 02:02
Thank you, I just had this same problem and your solution of re setting it worked. I can now get back to loving my Charge 3.
 Best Answer02-28-2019 02:43
02-28-2019 02:43
My fit bit 3 has been working great for two weeks. Not recording my sleep patterns but I am assuming that this is because I am very restless in bed.
However this morning it recorded nothing over to my phone re steps, even though it was sync, then on checking the screen was frozen.
Did as told ie connect to charger and hold button etc, but now have black screen. Helps I love my new device
 Best Answer02-28-2019 04:45
02-28-2019 04:45
I’ve had the same problem repeatedly since I got the Charge 3 in October. The resets discussed in this forum worked until the last time.
Fitbit is replacing the unit. Unless the new unit is bug free, I’m going back to the Charge 2. I’ve been wearing it since the latest glitch and had forgotten how hassle feee FitBit use to be. I especially like being able to see my steps easily by lifting my arm. I was never able to do that with the Charge 3.
Good luck with your fix.
 Best Answer02-28-2019 04:53
02-28-2019 04:53
Thank you very much for your quick response. I have a two year cover on my Fit bit 3 with the store. It is going back today for a replacement unit. I'll see how that goes. The one I have is only 24 days old and until 10.00 last night I was happy with it.
Again thanks for getting back.
Rowli in little Wales
 Best Answer02-28-2019 05:10
02-28-2019 05:10
Wanted to update my message as Fitbit has now offered to replace my Charge. While it’s been down, I’ve been wearing my Charge 2. It’s been a pleasure to return to this older, problem free friend.
 Best Answer02-28-2019 05:48
02-28-2019 05:48
 Best Answer02-28-2019 12:54
02-28-2019 12:54
Just had to reset my charge 3 it did work but disappointed that this needed done! Have took it off when swimming just in case so was gutted the screen was blank today good job I found this.
 Best Answer02-28-2019 13:41
02-28-2019 13:41
I tried the fix and it worked. However if it happens again, I'm returning it. I've only had it a couple weeks.
 Best Answer02-28-2019 15:22
02-28-2019 15:22
 Best Answer02-28-2019 21:03
02-28-2019 21:03
Same here and it wont reset 😭
 Best Answer03-01-2019 00:57
03-01-2019 00:57
 Best Answer03-01-2019 09:35
03-01-2019 09:35
Didn’t work for me. Still got blank display, but it’s has charge as it is still vibrating with notifications. This and it’s inability to recognise flights of stairs is not great
 Best Answer03-01-2019 09:40
03-01-2019 09:40
After a couple of attempts, it did reset and everything is now working.
 Best Answer03-01-2019 17:38
03-01-2019 17:38
Restarting it worked perfectly. Thank you so much.
 Best Answer03-02-2019 07:29
03-02-2019 07:29
Thank you for the tip, it worked!
