12-01-2018
12:33
14:34
12-01-2018
12:33
14:34
I've had my Charge 3 a little over a month. Last night my screen went blank. It was at 100% battery. It is still syncing with the app so I can see that it is still tracking my steps and sleep, etc. When I tried to restart it by placing it on the charger and holding down the side button for 8 secs. When I hold the button down it does a very quick pulse vibe about 4 times and then nothing. I've tried holding it longer than 8 secs also and still nothing. Very frustrated to be having this issue with a brand new product. Contemplating returning the one I bought my husband for Christmas and returning mine as well if not resolved immediately.
11-17-2019 06:57
11-17-2019 06:57
Scottg23: Thanks for taking the time to reply! Glad it worked and hopefully you won't be in the group that has to do it repeatedly.
will
11-17-2019 14:02
11-17-2019 14:02
The reboot does work for me but I'm now having to do it multiple times a day. This is very frustrating. I'm checking to see if it's under warranty still so I can get a replacement. I've had mine for 5 months. Extremely disappointed in this product.
11-17-2019 14:03
11-17-2019 14:03
The reboot works for me but I now have to do it multiple times a day. This is very frustrating. I'm checking to see if it's still under warranty so I can get a replacement. Extremely disappointed in this product.
11-18-2019 03:16
11-18-2019 03:16
11-21-2019 10:33
11-21-2019 10:33
OK, so I bought a Charge 3 a few months ago to replace the Charge 2 after having battery issues following the firmware upgrade. Well, stupid me, trusting fitbit products. Now I have this blank screen issue that pops up intermittently. I don't carry my charging cable around in my pocket to do the magic 'reset' sequence and have to wait several days to reset it. What the heck is wrong with the screen? What is the REAL issue here, why should I have to reset the device at all??
11-21-2019 10:34
11-21-2019 10:34
Why is the screen going blank in the first place? Why are users having to reset the device at all???
11-21-2019 15:28 - last edited on 01-23-2020 14:55 by LiliyaFitbit
I have no ideal, when I got my screen back i sync it everyday, try to hold the button when it is charging good luck
Moderator Edit: All-caps
11-24-2019 07:51
11-24-2019 07:51
Having the exact same issue but the recommended solution does not work. Device syncs with the app but the screen is gone.
11-24-2019 16:27
11-24-2019 16:27
12-01-2019 14:23
12-01-2019 14:23
The same problem, very disappointed. I will not recommend this brand.
12-02-2019 03:19
12-02-2019 03:19
12-08-2019 05:43
12-08-2019 05:43
This did the trick
12-17-2019 06:07
12-17-2019 06:07
No, this did not work, nothing works. Only had this fitbit for 9 months, what a waste of money
12-17-2019 06:38
12-17-2019 06:38
Anec26: If only 9 months, you can get it replaced under the 1-year warrantee.
12-17-2019 07:02
12-17-2019 07:02
Yeah, unfortunately I got in on Schpock, so I don't have a warranty. It was however brand new and sealed, that's why I was confident on getting it, and now this...
12-17-2019 08:32
12-17-2019 08:32
I have tried this several times with no success (no smiley face, nothing), so I read to try and change clock face on app to see if that generates any smile or response. When I hold button down, I get varying # of little buzzes so I think it is not dead, but pretty frustrating.
12-17-2019 08:45
12-17-2019 08:45
12-17-2019 08:51
12-17-2019 08:54
12-17-2019 08:54
Don't have warranty unfortunately
12-17-2019 10:09
12-17-2019 10:09
Thanks for your solution of putting it in the charger and holding the button for 15 seconds. By 8 seconds I was seeing a little lighted line across the screen. By 15 seconds, I had the smiley face. I took it out of the charger, put it back in, and all was normal!
