11-29-2020 17:11
11-29-2020 17:11
Add me to the many with this issue! The screen is now only visible in complete darkness; even then, only the top and bottom of the screen are visible and it’s so dim that I have to hold it right in front of my eyes.
I read all the forum questions on this, so I have checked the brightness setting and sleep mode (not easy as described above), tried the restarts, tried changing the clock face. Nothing. Right now it is useless as a watch, but still pairs with my phone. Help! This is clearly a common problem. The watch is two years old, so out of warranty.
11-29-2020 19:33
11-29-2020 19:33
Same issue! I replaced my last Charger 3 because of this same issue. Now my new one is doing the same. Black screen! ☹️
11-30-2020
11:29
08:26
11-30-2020
11:29
08:26
@Blankscreennow @Sheri73099 It's great to have you here!
Let me help you with your Charge 3 screens not working. @Blankscreennow thank you for troubleshooting this issue. Since the issue persists I have created a ticket so our Support team can further assist you via email.
@Sheri73099 you don't mention any troubleshoots so I suggest you restart your tracker by doing the following:
Let me know how it goes.
Best Answer11-30-2020 11:52
11-30-2020 11:52
I had same problem. I reset and see the darkness went away by resetting. Thank you
11-30-2020 14:47
11-30-2020 14:47
I have tried resetting. Nothing. Black screen.
11-30-2020 18:31
11-30-2020 18:31
I’ve tried everything and still no screen. Says my tracker is paired on my phone and put in the numbers that just are not able to be seen on this watch. The only thing the watch does is vibrate. Can’t pair the dam thing if I can’t even see anything on the screen. Sad to have spent that much on a watch that I thought had a good reputation and have it end up as expensive junk. 😢
11-30-2020 20:52 - edited 11-30-2020 20:55
Mine went completely black yesterday. When I try to charge it the watch gets extremely hot! Nothing even shows on the screen when I have it on the charger. No vibration no battery icon. Nothing.
12-02-2020
11:33
08:26
12-02-2020
11:33
08:26
@MSS-1965 @Rondaswatch @rj2peas It's great to see you in the Community.
@MSS-1965 really happy to hear that the restart helped fix the issue.
@Rondaswatch @Sheri73099 I have created tickets for you two. Make sure you check your email service as you will be contacted by Support via this way.
@rj2peas I noticed that you already have a ticket with Support so please work for them to find a solution.
Keep me posted.
Best Answer04-14-2021 13:31
04-14-2021 13:31
Same problem here, I tried the reset and got the Smiley face but it never vibrated as indicated. Change clock face, nothing has helped. 😞
05-05-2021
08:02
08:25
05-05-2021
08:02
08:25
@CC43081 It's good that the community is growing!
Sorry to hear about this and thank you for troubleshooting this issue. Since the issue persists I suggest you contact our Support team for further assistance. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Hope this helps.
