09-25-2022
00:01
07:41
AndreaFitbit
09-25-2022
00:01
07:41
AndreaFitbit
I had the same problem. I did the device reset, then went into the settings on my Charge 3, and cycled through the ‘Brightness’ settings (going to all options, then back to auto’. Went back to the main screen and it suddenly responded like it should (brightness was correct).
Moderator edit: format and label.
09-27-2022
07:42
09:05
09-27-2022
07:42
09:05
Welcome to the Fitbit Community, @Con_Mitro. Thank you for sharing the steps you followed in order to get correct brightness on your Charge 3.
This could be useful for other users.
Best Answer10-04-2022 02:23
10-04-2022 02:23
Your Fitbit's ambient light sensor looks like a black dot on the side of your Fitbit device. If this is blocked, your screen will usually go dark automatically. Oftentimes, we need to adjust the brightness of our Fitbit's screen. We suggest you go to a dark room or wait until dark, then take a look at your Fitbit
Regards,
Will
07:36
09:05
10-04-2022
07:36
09:05
Thanks for getting back to us and for your advise @willjoe.
