07-10-2021 21:28 - last edited on 07-11-2021 14:39 by LiliyaFitbit
Dutch:
Mijn charge 3 is vervangen en de nieuwe wil niet reageren op het draaien van de pols. Het scherm gaat alleen aan als ik op de knop druk. Knop lang ingehouden: enkel "scherm activeren" staat aan. Bij instellingen staat de helderen op automatisch/normaal (beide opties geprobeerd) en hij doet het nog niet
My best English:
The screen won't react to wristmovement. If I push the button for 2 seconds online activate screen is on. And the brightness of the screen is automatic/normal (both optioneel will not work)
The only way to put on the screen is to push te button...
A bit dissapointed in the charge3... this is already my second replacement and unfortunately there are problems with every charge3.
07-11-2021 14:38
07-11-2021 14:38
Welcome to the Fitbit Community, @KarinAntwerpen.
Thanks for the details shared in your post. I understand how you are feeling and recommend doing the following: press and hold the button on your Charge 3 and swipe to access the quick settings screen. Make sure Screen Wake setting is on and Sleep mode and DND are turned off. When you turn off the setting, the icon appears dim with a line through it. For more information about navigating your device, see How do I navigate my Fitbit device?
Thank you for posting in two languages, we currently support French, Italian, Spanish, German, Korean, Chinese, Japanese and English and hope to support more locales in the future.
By the way, I've moved your post to Other Charge Trackers board so we can keep our forums organized.
Hope this helps.
