12-17-2018
03:13
14:31
12-17-2018
03:13
14:31
Unable to scroll across to activities
02-12-2020 13:10
02-12-2020 13:10
I tried all you suggested, it’s still not scrolling. It’s charging, syncing, displaying main click face, but can’t scroll either down or side. What else can I try?
02-25-2020 02:24
02-25-2020 02:24
Thank you, that was too easy.
03-17-2020 13:18
03-17-2020 13:18
Reset of my Charge 3 did not clear the problem. Device worked perfect for 11 months and not is flaky. It snchs sometimes, doesn’t scroll, goes blank, will not respond to button pushes but will vibrate like it acknowledged my button push. Then for no reason, an hour later it works but still doesn’t scroll normally. Are these devices designed to fail after one year?
04-18-2020 10:04
04-18-2020 10:04
Thanks
your tip worked for the reset👍🏼
04-27-2020 03:39
04-27-2020 03:39
This fix worked fine for me back up and running (walking) again
06-04-2020 10:37
06-04-2020 10:37
Screen won’t scroll. I plugged it in to charging cable. Squeezed sides for 8 seconds. Screen went blank. Still won’t scroll 🙁
07-11-2020 15:26
07-11-2020 15:26
Tried everything and still not working
07-22-2020 12:25
07-22-2020 12:25
I did this at least 4 times.... then did a factory reset and still it will not scroll.
11-07-2020 16:34
11-07-2020 16:34
I have tried this numerous times but it still works t scroll. The only thing I can see is the time.
11-07-2020 16:36 - last edited on 11-08-2020 17:29 by LiliyaFitbit
Wont scroll up or down. Left or right.
Update:
What did you do to fix it?
Moderator edit: merged replies
11-08-2020 06:20
11-08-2020 06:20
11-30-2020 05:52
11-30-2020 05:52
I am now on my fourth charge 3 in a year. After resolving issues with lines on screens and exercise shortcuts constantly changing to pilates with replacement watches, I now have the issue that the screen won’t scroll. All attempts at resolving lead to a completely black screen. Once I get the screen back it’s back to square one and it won’t scroll
i have tried to restart, uninstalled and reinstalled the ap. turned blue tooth off and on, restarted my phone, uninstalled and reinstalled the device and changed the clock face numerous times.
any other suggestions gratefully received - I can’t do a long restart as this causes the screen to go completely black - I get the vibrations but no smiley face etc..
03-28-2021 07:42
03-28-2021 07:42
Unfortunately this didn’t work for me! Not sure where to go from here. Any suggestions?
03-28-2021 10:05
03-28-2021 10:05
03-29-2021
06:42
09:53
03-29-2021
06:42
09:53
Hello everyone. @darcief, @Franciewood It's great to see you around!
@darcief If you haven't done so, my best recommendation is to contact our Support Team for further assistance. Click here to get connected. @Franciewood There is an empty post. Can you provide more details if you need further assistance for the inconvenience you reported before?
I look forward to your response.
