02-12-2019
19:30
11:48
AndreaFitbit
02-12-2019
19:30
11:48
AndreaFitbit
Many times when i turn my wrist to try to activate the screen, it doesn't turn on and i have to do it many times before it does which can be frustrating
Moderator edit: format.
01-20-2020 10:14
01-20-2020 10:14
How do I find screen wake up?
05-25-2020 21:27
05-25-2020 21:27
This worked for me too! Thank you
07-03-2020 09:37
07-03-2020 09:37
07-03-2020 13:54
07-03-2020 13:54
Tried the method but screen is black, I felt no vibration
07-19-2020 09:47
07-19-2020 09:47
This was my issue! Thanks so much!!!
07-20-2020 18:34
07-20-2020 18:34
Pressing the side button worked. Just scroll up when you see a different display than the normal one and you should see screen wake. Somehow mine was turned off :s.
07-20-2020 20:09
07-20-2020 20:09
07-21-2020 09:19
07-21-2020 09:19
Don't know quite how it turned off but that's solved the issue thanks
08-10-2020 11:26
08-10-2020 11:26
For me, tapping the screen awake didn't do anything, rather I had to hit the sleep setting above that and it turned on my awake.
08-10-2020 14:57
08-10-2020 14:57
08-12-2020 11:13
08-12-2020 11:13
YES!!! I must have somehow turned my Screen Wake off and now it works! Thank you!
08-17-2020 10:21
08-17-2020 10:21
Nothing happens when I tap "Screen Wake" Also other settings are not active
08-17-2020 17:20
08-17-2020 17:20
mine doesn’t show a wake on it turns on after i charge it, but it just shuts off after and i can’t get it to turn back on. any help?
11-17-2020 06:08
11-17-2020 06:08
thank you for this; but in the last couple of weeks I have had to use your technique more than once because the screen wake keeps shutting off? I am not shutting it off so cannot figure out why this would happen. I have only owned this Fitbit for 6 months, it shouldn't be having these troubles so soon.
Thank you again for your help in figuring out how to get my screen to show when I twist my wrist. H
03-09-2022 01:01
03-09-2022 01:01
Hi. Thank you I knew that I must have turned something off and I could not find where it was.
05-22-2022 09:05
05-22-2022 09:05
Nothing works....can someone PLEASE PLEASE tell me how to get my screen wakeup back. I have done all of your advice and I see screenwake-up but when you say "choose it" HOW do you choose it? It is sort of grey but does not appear to be off. How do you CHOOSE an option when you are scrolling through 20-30 screens? How do you tell your watch not to delete all settings when you do an upgrade? Any help would be greatly appreciated. Ready to throw it in the river, and bummed because it worked great for a month where it would wake up when I moved my wrist and would do this fireworks thing when I hit my step goal, but now it does neither despite trying many different things to get these back.
06-28-2022 13:19
06-28-2022 13:19
tap the screen twice to get to the clock menu. Fitbit shows this in the tips quite frequently and it always works. Annoying though. I miss having it turn on when I turn my wrist.
