10-16-2020
08:00
07:31
JuanJoFitbit
10-16-2020
08:00
07:31
JuanJoFitbit
Disappointed with this, it broke a little while ago but it's frustrated me so much I have ignored for a while.
There is nothing on the screen, it vibrates when you connect to a charger, and when I hold in the button to do a reset (as FitBit recommends on all posts) it vibrates constantly until I release then does nothing.
Any ideas?
Seems you can't get these repaired anywhere either!
10-19-2020 07:30
10-19-2020 07:30
Hi @JenniCharge3, it's great to see you in our Fitbit Community. I'd like to follow up and help you with your Charge 3 since the display won't turn on. I totally understand how you feel about this and I appreciate the time spent trying to get this issue resolved before contacting our forums.
I'd like you to try a long restart. To do so no your device, follow the steps below:
Keep me posted on the outcome.
Best Answer10-19-2020 12:14
10-19-2020 12:14
hi, i am having this same problem. ive plugged it in and when i hold the button it vibrates constantly until i release it then nothing happens. it doesn't vibrate when i plug it in.
