10-28-2020
09:27
07:06
JuanJoFitbit
10-28-2020
09:27
07:06
JuanJoFitbit
Hi. I haven't used my charge 3 in a few months. The battery is completely drained. I had it on the charger overnight,but it still has a blank screen. It does give me a long buzz after I put it on the charger. I can't get it to connect to my Android either to try and change the clockface. I have also held the button for 8+ seconds. Is there anything else that can be done?
10-29-2020 07:05
10-29-2020 07:05
Hi @SunsetRunner, welcome to our Fitbit Community. I'd like to follow up and help you with your Charge 3 since the screen won't turn on even though you have changed the clock face and restarted it before contacting our forums.
Please try a long restart. To do so on your device, follow the steps below:
Keep me posted on the outcome.
10-29-2020 07:05
10-29-2020 07:05
10-29-2020 07:12 - edited 10-29-2020 07:41
@JuanJoFitbit When I hit the button it vibrates the entire time (15 sec) until I stop pressing it. But the screen does not come o
10-29-2020 09:06
10-29-2020 09:06
Hi @SunsetRunner, thank you for getting back and trying the recommended troubleshooting steps.
Since the issue persists, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Let me know if you have any questions.
10-29-2020 09:12
10-29-2020 09:12
I have the same problem with my. Fitbit, can you please ask the support team to contact me as well?
10-29-2020 17:17
10-29-2020 17:17
I am having same issue. It happened couple days ago when screen went blank. Next day I tried 15 second trick and it worked for one day and it went blank. Now it don’t turn on. I have to call customer service.
11-07-2020 19:57
11-07-2020 19:57
I am also having the same problem and tried everything that was suggested. Please ask the support team to contact me, to help with the problem. Thanks
11-07-2020 21:06
11-07-2020 21:06
My charge 3 screen went black two days ago. Please help to investigate and solve this problem. Thanks.
11-08-2020 02:06
11-08-2020 02:06
Hello!
My Charge 3 went black the other day and I tried this method. However, after I shut down the device (indicated by the 7 short vibrations), the device doesn't turn on after I plug it into the charging cable.
