05-01-2019
00:39
11:08
05-01-2019
00:39
11:08
Hello All!
So I decided to upgrade from Charge 2 to charge 3 and I am currently registering my fitbit with the insurance provider. I'm asked for the serial number. On the box, it states one thing (12 alphanumeric), but when I go on the Fitbit site and look at the URL that contains my serial number, it conflicts (also 12 alphanumeric). I did pick up that the letters and numbers in both serials are the same, just in a different order. Which serial should I use? the one on the box? or the one showing on the url??
The fitbit packaging was brand new, not tampered condition from where I purchased it (a vendor at the airport).
any and all suggestions is welcomed!
Thank you!
05-01-2019 00:51
05-01-2019 00:51
not sure if this makes a difference, but my fitbit is a Charge 3 Special Edition (aka the one with the lilac purple fabric band and black silicone band). I neglected to mention this in the original post and can't seem to edit it... ![]()
Best Answer10-18-2020 21:13
10-18-2020 21:13
Hello, were you able to get any further clarity why the 12 alphanumeric on the url is in different order vs the one on the box?
I recently bought an 'open box' charge 3 at a liquidator and observed one of the straps has been switched. So would like to confirm that the device belongs to the box. Similar to what you observed, the serial# on the box and url comprise the same 12 alphanumeric, but in different order.
Thanks!
