05-23-2019
23:41
11:08
05-23-2019
23:41
11:08
My fit bit is just giving me the option to log Pilates . I don’t even have it on my app!? Any suggestions?
05-30-2019 07:59
05-30-2019 07:59
Welcome to the Community Forums @leelea134!
Like @Brownman248, I was also experiencing the same. I fixed mine by going into the exercise shortcuts and deleting all of the ones listed (my Charge 3 was showing Pilates, Pilates, Pilates but my app listed run, treadmill, bike etc). Then, I re -added the ones I wanted and synced my phone again. ![]()
If that doesn't work, please be so kind to set up your Charge 3 as a replacement device by following these instructions:
Thanks so much for your help @Rich_Laue!
Give this a shot and let me know the outcome, I'll be around.
05-24-2019 06:27
05-24-2019 06:27
Im not sure what your asking @leelea134
Ste you saying that Pilaties is an option on the Charge 3
On the Fitbit app, Pilaties doesn't show as a selected event in the settings?
Try rearranging the loaded events through the Fitbit app. After they sync I word expect Pilaties to be removed.
05-26-2019 06:12
05-26-2019 06:12
05-26-2019 07:09
05-26-2019 07:09
I had the same issue, go to you exercise shorts cuts. I had to remove some and then re add them, took a while for it to sync but eventually it was removed. I was actually grateful I had that issue because I didn’t know I could re arrange them.
Best Answer05-29-2019 09:22
05-29-2019 09:22
Please see question 2 of the FAQ
How do I track my workouts with my Fitbit device?
05-30-2019 07:59
05-30-2019 07:59
05-30-2019 08:32
05-30-2019 08:32
Best Answer05-30-2019 08:33
05-30-2019 08:33
Thank you so much, it has worked for me too 😊
Best Answer05-30-2019 08:58 - edited 05-30-2019 08:59
Awesome @leelea134!
I'm happy to hear the steps provided did work for you.
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted.
I hope you have a nice day!
06-04-2019 06:40
06-04-2019 06:40
Im having this same problem. Where do I find the exercise shortcuts?
Best Answer06-04-2019 09:23
06-04-2019 09:23
I found it easiest doing it via the website on my computer
1. Log in to your fitbit.com dashboard and click the gear icon in the top right corner.
2. Click Settings > Devices.
3. Scroll down to Exercise Shortcuts.
4. Click Edit Exercise Shortcuts to choose the exercises you want on your device.
Best Answer06-04-2019 10:40
06-04-2019 10:40
Welcome on board @Brittanycoop!
As my friend @leelea134 has suggested, in the Fitbit app:
Fitbit.com Dashboard:
Hope this helps, let us know if you need further assistance. ![]()
06-04-2019 10:51
06-04-2019 10:51
For future reference this is explained on fitbit's help site. Link to help found below.
See question two of the FAQ.
06-05-2019 13:14
06-05-2019 13:14
I am having the same problem with the Fitbit only giving me run, bike and Pilates. I have tried deleting shortcuts and readding them and syncing phone. Nothing changes. Have tried setting up new device. It syncs with Fitbit but then it aborts the action. I am super frustrated at this point. I have tried both of these fixes numerous times and nothing changes. Anyone have any ideas how I can get this working correctly again?
Best Answer06-05-2019 14:38
06-05-2019 14:38
I am also having this issue. Got my charge 3 yesterday. When I looked at first there was 5 exercise/sport options. When I went to log my weight training this am my choices had changed to run or Pilates x 4
Best Answer06-06-2019 09:53
06-06-2019 09:53
Not sure about you but this morning my Charge finally switched back to my 5 chosen exercise shortcuts. It took over 36 hours after I went on my Fitbit account on my laptop before it worked. Hope yours fixes itself.
Best Answer06-09-2019 04:35
06-09-2019 04:35
Good morning all! I had the same thing happening - running and 5 Pilates. I tried the recommended fixes but to no avail. I wound up deleting my charge 3 and adding it again. That worked!
Best Answer06-09-2019 11:04
06-09-2019 11:04
Thanks I also tried the fixes suggested but didn’t work. But 36 hours later, the Charge 3 fixed itself. Now dealing with the battery draining itself after 2 days from a complete charge.
Best Answer06-30-2019 15:48
06-30-2019 15:48
where do i see the exercise i want to push a button to track, not sure how to get to them?
Best Answer06-30-2019 19:24
06-30-2019 19:24
