05-24-2019
07:20
11:01
05-24-2019
07:20
11:01
Hi,
My fitbit changed all of the exercise modes I have selected for it to pilates, so I now have 6 options, all of which are pilates.
This isn't reflected in the dashboard, which still holds the original options that I chose. I've tried moving these around a little and hitting 'save', then syncing the watch, but still, only pilates.
Is there a way to fix this or do I just have to take up pilates?
05-25-2019 07:18
05-25-2019 07:18
Hello @Metcon23, it's nice to see you around! Thanks for trying to solve this issue prior contacting us. Nice way to go!
I was experiencing the same, but I fixed mine by going into the exercise shortcuts and deleting all of the ones listed (my Charge 3 was showing Pilates, Pilates, Pilates but my app listed run, treadmill, bike etc). Then, I re -added the ones I wanted and synced my phone again. ![]()
If that doesn't work, please be so kind to set up your Charge 3 as a replacement device by following these instructions:
Give this a shot and let me know the outcome, I'll be around.
07-27-2019 06:37
07-27-2019 06:37
My fitbit changed 3 of my exercises to Pilates. I do not do that. Changed them in the phone but it did not change them in the watch. I tried to reload the Charge 3, it will send the numbers, I put them in but then the message is something went wrong and I should abort. Can anyone help?
Best Answer08-12-2019 22:31
08-12-2019 22:31
I am currently having the same problem. Has anyone found a solution for this?
Best Answer08-15-2019 07:58 - edited 08-15-2019 07:58
Welcome to the Community Forums @ddtkmw! I'm very sorry for the late response. Thanks for following the steps suggested above. Since the recommendation didn't work, please be so kind to set up your Charge 3 as a replacement device by following these instructions:
Welcome on board @awalters2010. Please go to the exercise shortcuts and delete all of the ones listed. Then, re -add the ones you want and sync with your phone to save the changes.
Give this a go and let me know the outcome.
Best Answer08-28-2019 11:45
08-28-2019 11:45
I have this same problem. I keep resetting and resincing but within a coupld of days it reverts to pilates again. i'ts getting annoying.
Best Answer08-29-2019 12:36
08-29-2019 12:36
@tommyboy649 Welcome on board. Thanks for the steps you tried so far in order to solve this situation.
As recommended above, please be so kind to set up your Charge 3 as a replacement device by following these instructions:
Best Answer05-08-2020 00:05
05-08-2020 00:05
I’ve tried resetting and following the steps and it just says something went wrong and won’t re connect it as a new devise!
what do I do?
Best Answer05-27-2020 14:31
05-27-2020 14:31
To clarify tjusy fix, which I have had to do twice in the past week...🙄...you have to 'un-pair' and delete your current Fitbit device from the app then 'set up a new device'.
It should restore the exercise options on the device. 👍
Best Answer05-27-2020 14:32
05-27-2020 14:32
Sorry, should have been 'this' 🤦🏼:female_sign:...of course, my autocorrect didn't correct it 🤷
Best Answer06-30-2020 10:25
06-30-2020 10:25
I have the same issue. I tried deleting the exercises, setting up my Charge 3 as a replacement device and deleting the Fitbit app. No luck, I do get an error message with an abort when trying to replace device.
