01-12-2019
23:12
13:05
01-12-2019
23:12
13:05
Because my original watch was declared defective, Fitbit kindly sent me a new pebble. It arrived while I was out today, so I started setting it up this evening, late as it is.
Everything was going well until I accidentally closed the fitbit app during the initial new watch update. Now the pebble will either not respond to anything, or when I hold the button, the white line will fill and then that's it. It stays a white line.
The Fitbit app, I've uninstalled and reinstalled and restarted my phone, but it can't find the watch. It asks me if the watch is powered on. And it's on its charger, white line glowing, but I guess not actually alive. Not sure what to do here. Any ideas?
01-14-2019 20:12
01-14-2019 20:12
Solution: I'm being a sent a replacement for my replacement.
I was able to use live support today. They had to escalate it to Special support who, I guess, declared my new pebble dead. Thank you for your original response, regardless.
Lesson here, kids: do NOT let your firmware update/set up get interrupted.
01-13-2019
05:00
06:59
01-13-2019
05:00
06:59
It's great to see you around @ckitty.
Thanks for troubleshooting this display issue by yourself. Have you tried to restart your tracker? If you haven't, I recommend restarting it by doing the following:
Let me know the outcome. ![]()
01-13-2019 20:45 - edited 01-13-2019 20:54
Thank you for your response @AlejandraFitbit However, my Charge 3 won't restart. When I try to restart it, it doesn't do what it's supposed to be doing.
When I posted this last night, when I'd hold the button down (securely attached to the plugged in charger), an empty line would appear and then, with each pulse from the watch, the line would fill with white. And that was it. The line would just stay there and nothing else would happen.
Right now is the first chance I've had to work with it since last night, and it's just not acting right. I've been messing with it for a little bit, and, at first, it wouldn't do anything when I'd press the button. Randomly, a smile icon appeared when re-seating the pebble on the charger. So, I held the button, hoping it was capable of doing a restart. After 7-8 seconds, the empty line appears instead of the smile icon, it starts to fill, but it will only get to 3 or 4 pulses before shutting off again.
*edit 1: it's gotten up to 6 pulses in filling the line before it shuts off again. But the result is the same, no restart. I've tried pairing through the app anyway, and it's giving me the same message, asking if my Charge 3 is powered on.
*edit 2: it's a full white line again and that's how it will stay until I take it off of the charger.
01-14-2019 20:12
01-14-2019 20:12
01-16-2019
03:14
06:58
01-16-2019
03:14
06:58
Thanks for the update @ckitty. I am glad to hear that your tracker is being replaced. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up! ![]()
Best Answer02-05-2019 19:18
02-05-2019 19:18
Just bought a charge 3 today and it is showing a horizontal white line across the display. It doesn’t go away after being rebooted or the firmware update finishes. What do I need to do?
Best Answer04-13-2019 07:03
04-13-2019 07:03
I have literally just taken delivery of my replacement Charge 3 from customer services after having experienced the "blank screen" problem. After setting up and updating, there is a persistent thin bright white line across the screen about 3mm down from the top. Have tried all the reset advice to no effect. Any ideas?
07-31-2020 08:47
07-31-2020 08:47
Hey!
I just started experiencing this today. There is a white line running vertically on my fitbit charge 3 screen. I did not knock my screen or drop my fitbit anywhere. My fitbit is only 4 months old. Does anyone have any idea on what I should do?.
I did try to reboot but that did not work. =(
07-31-2020 09:40
07-31-2020 09:40
I’m having the same problem with the white lines on my charge three. I’ve done everything that was suggested and nothing has helped. I would like to know what to do next. This is my second charge three because the first one didn’t work also but for a different reason. Thank you
