01-18-2020
21:33
17:44
01-18-2020
21:33
17:44
When I tap exercise on my Fitbit, the options are Run, Bike, Swim, then it has Pilates 3 different times. I’m getting back into fitness and none of these are really things I do often. I wish I could add other options for quick access. Thanks!
01-18-2020 23:00
01-18-2020 23:00
You can have up to 7 exercise shortcuts. On your dashboard click on the gear and choose settings.
Look for exercise shortcuts. Change to what you want. Make one of these Workout.
Device will need to sync before it takes place.
I use Workout mode to capture and exercise that is not listed.
Then I rename it as I state below
Then on the computer dashboard make a custom exercise. This will be at the bottom of the exercise tab Name it what you want.
Then on your device push in the button until you get to the exercise screen. Once there Swipe through until you see the Exercise or use Workout mode Hold in the button to start and when done Hold it back in to stop it.
Once it syncs you can rename it to the custom one you set up.
The manual explains it here and explains it very well
Wendy | CA | Moto G6 Android
01-20-2020 11:31
01-20-2020 11:31
