10-15-2018
07:55
15:06
10-15-2018
07:55
15:06
Hello, my Charge 3 been working fine 4 days, but all of a sudden it was unable to sync and showed an error as Tracker Not Found. I had to do a "New Device / Replace Your Tracker" to get it back to work again. Why will this happen?
Thanks,
-Siva
04-13-2019 22:04
04-13-2019 22:04
I haven't been able to sync my charge 3 for 4 days. I tried rebooting it a few times and I and removed the app and reinstalled it. It's still not syncing. How do I fix this without losing my data? I only have the firbit 2 mths.
07-23-2019 20:49
07-23-2019 20:49
Still nothing. This is day 2. Managed to finally get it to repair and sync last night after an hour of playing around with it but lost a whole days worth of stats cause it wouldnt sync.
Uninstalled, reinstalled, unpaired, repaired, rebooted, holding side button for 8 secs while on charge only loads to half way then shuts off.
Getting frustrated. Can you help?
07-24-2019 02:49
07-24-2019 02:49
07-24-2019 05:34
07-24-2019 05:34
08-16-2019 20:20
08-16-2019 20:20
Did you find out the reason why it won't sync and why it says tracker not found?
I have exactly the same issue and also tried everything you already tried.
I'm very frustrated. A few days ago everything was still fine and all of a sudden that started.
Mine synced on and off but will not stay connected. 😠
08-17-2019 10:24
08-17-2019 10:24
08-24-2019 05:20
08-24-2019 05:20
I have had same issue in morning. I put on charger and do a reboot ( press side button while on charger and get 🙂 smile face.) I have pixel 3. I have noticed this issue since the updated the app.
08-24-2019 07:56
08-24-2019 07:56
08-28-2019 00:42
08-28-2019 00:42
as working fine too until the new app came along. Since then firmware updates have just totally screwed me. Despite doing full resets and re-pairing of the device, It just will not sync. This device and the software (probably the software) is just not fit for purpose.
08-28-2019 11:01
08-28-2019 11:01
10-22-2019 19:27
10-22-2019 19:27
Same issue, same activities, pairs and the device not found error comes around again. This is even a replacement device for another that just stopped working, I am considering giving up on Fitbit all together
11-21-2019 00:16
11-21-2019 00:16
Hi,
My charge 3 synced 19 November and was working. Yesterday after a yoga session, I synced as always but the app said device not found. I attempted a few times, same error. I did a reboot on the device, restarted my phone, turned Bluetooth off and on again. Still nothing. I also tried a hard reset.
I followed the advice and unpaired from my Bluetooth. Now there's no device on my account. I started the setup process and the app found my device but couldn't connect. I tried multiple times but not working. My device was 86% charged and I then decided to call it a night and go to bed. The device was still on.
This morning when I woke up, my charge 3 was off, didn't respond to touch and doesn't come on when I plug it in to the charger and doesn't respond to hard reboot attempts.
Please advise. This is my 3rd charge 3 in 11 months. I'm not sure what the issue is, if it's the charge 3 specifically or just my poor luck.
11-21-2019 06:13
11-21-2019 06:13
I have been round and round with my charge 3, as it can no longer connect with my app, does not keep time, etc. I have given up and will be purchasing a Samsung and advising people I know not to purchase a fitbit There has been no attempt on their part to resolve this ongoing issue.
11-21-2019 08:49
11-21-2019 08:49
11-21-2019 09:40
11-21-2019 09:40
I did all those things My watch is basically unusable at this point
11-21-2019 11:03
11-21-2019 11:03
11-22-2019 08:18
11-22-2019 08:18
Thanks for all the feedback everyone. I have contacted fitbit. Will have to wait and see what the next steps are although I suspect it'll need replacing.
Very disappointing I must say.
02-10-2020 20:12
02-10-2020 20:12
I have had same issue recently after no issues since I purchased charge 3. Have followed all directions in forums and from support staff, still nothing and still will not stay synced and device cannot be found. Super angry as support gave me a case number and then said I would not get a response but rather should borrow a similar device from friends or family until a software update fix arrives magically from the app updates. Not happy. I was told a “highly unlikely issue” due to my device not responding to fix. However seeing numerous posts online with same struggle. Any advice how to fix? Thanks
02-10-2020 20:23
02-10-2020 20:23
02-10-2020 20:36
02-10-2020 20:36
