06-09-2021
09:10
09:16
WilsonFitbit
06-09-2021
09:10
09:16
WilsonFitbit
Charge 3 - shows 001 or Smiley face - tried resetting many many times - no green lights on back - can’t change clock face because it won’t synch now just a continuous buzz when I press the button. There must be a way to fix - it’s only 1 1/2 years old
06-09-2021 09:19
06-09-2021 09:19
Hello @Terrydearden. Welcome to the community forums!
Thank you for the detailed information and for the troubleshooting steps you've tried prior to posting. If restarting your Charge 3 didn't work, I recommend performing a long restart to see if that makes any difference. The long restart is different than the basic one and you can complete the process by following the instructions below:
If after trying this, your Charge 3 is back to normal but it still doesn't sync, please try these steps: Why won't my Fitbit device sync?
Hope this helps.
Best Answer06-09-2021 09:19
06-09-2021 09:19
Hope this helps.
Best Answer06-09-2021 11:29
06-09-2021 11:29
Best Answer06-10-2021 05:09
06-10-2021 05:09
@Terrydearden Thanks for your reply.
@Terrydearden wrote:
Sent from the all new AOL app for iOS
Seems that there wasn't more information included in your response. Do you have any other questions or inquiries?
I look forward to your response.
