11-27-2020
19:32
05:25
JuanJoFitbit
11-27-2020
19:32
05:25
JuanJoFitbit
I am trying to get help with my Charge 3!
I have rebooted, restarted etc. The device worked for a few days after i first rebooted it -but now it won't do anything but drain the battery.
The green light I usually see under the Fitbit is not there. There is only a solid red (bright) light on the bottom of the thing- and it drains the battery in no time.
I am sick of this! You've already replaced it once. Do i have to ask you to replace it again?
I am about to give up on Fitbit. There's got to be a tracker that is more reliable than your product.
The original purchase was from Macy's.
Thank you.
11-28-2020 05:24
11-28-2020 05:24
Hi @333Hiker, it's great to see you in our Fitbit Community. I'm sorry to hear about the battery draining issue that your Charge 3 has experienced. I totally understand how you feel about this and I appreciate the time spent trying to get this issue resolved before contacting our forums.
Please try a long restart. To do so on your device, follow the steps below:
After this, try the tips that are listed in this help page in order to improve the battery life of your Charge 3.
Finally, monitor your tracker during the next 24 hours and see if the red light disappears and the battery doesn't drain fast.
Keep me posted on the outcome.
Best Answer11-28-2020 17:52
11-28-2020 17:52
I tried this. To no avail.
I give up.
I just bought a new Charge 4 because I'm fed up with this unreliable device.
That doesn't really seem fair, does it?
I have been a loyal Fitbit user since 2015. I'm too tech impaired to learn how to use a different brand of tracker. I guess you are going to keep turning out the same garbage that you have been. And i'll continue to be another sucker who keeps buying it!
The LEAST you could do is give me some kind of rebate for the new Charge 4 i just bought (order #1003019716920)
Valerie Matonis
Best Answer11-28-2020 22:10
11-28-2020 22:10
I’m having the same problem with my charge 3. The battery drained quickly within 1 hour of full battery level. I bought it from PC World in Ireland but living in UK now. This has been causing stress for me. What should I do again.
Best Answer11-28-2020 22:11
11-28-2020 22:11
