05-21-2019
06:33
11:08
05-21-2019
06:33
11:08
I am now getting an exclamation mark on my Charge 3 when the battery level drops to 18%. There is no warning given previously that the charge is low and so my Charge 3 needs to be charged immediately. Is this a software issue or a problem with the battery?
05-22-2019 04:18
05-22-2019 04:18
Welcome on board @colincam! This is expected behavior, it indicates that you have 1 day of battery life yet. You should be able to dismiss it by pressing the button.
Please let me know if there's anything else I may do to assist you with.
Best Answer05-22-2019 04:18
05-22-2019 04:18
Best Answer05-22-2019 06:57
05-22-2019 06:57
Thanks. I'll try that when it goes down to 18% next time. This must be a new feature as it has never happened before.
Best Answer05-22-2019 12:20
05-22-2019 12:20
Hello @colincam! This got implemented in the latest firmware version of Charge 3. ![]()
I'll be around if there's anything else I may do to help you out.
05-29-2019 01:42
05-29-2019 01:42
Thanks. That worked as you said it would! 🙂
Best Answer05-29-2019 11:06 - edited 05-29-2019 11:06
Hey @colincam! It's nice to hear that. ![]()
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted.
I hope you have a great day!
Best Answer07-05-2019 12:45
07-05-2019 12:45
Hi just received a replacement charge 3. I have charged the watch, however I keep getting the battery exclamation sign. I can not update the replacement as it keeps telling me the battery is low, even when it is plugged in. When I unplug it, it is dead. What’s the solution?
07-08-2019 10:59
07-08-2019 10:59
Welcome to the Community Forums @Pete-31! Thanks for reporting the set up issue with your Charge 3 replacement.
While reading your post I was wondering if the mobile device you're syncing with is included in our list of supported devices? You can see the list at: Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
I've taken the time to review your support case and it seems that you cannot setup your Charge 3 due to you had an Ionic prior to receive the Charge 3. Note that you can't connect multiple devices that use the Fitbit App Gallery to one account. For Fitbit Charge 3, Fitbit Ionic, Fitbit Inspire series, and Fitbit Versa series, only connect one of these devices to your account at a time.
If you've not done so, I'd suggest to try the following:
Give this a go and let me know the outcome. ![]()
Best Answer08-16-2020 00:07
08-16-2020 00:07
Tha mark won’t dismiss
