10-09-2020
15:37
10:13
10-09-2020
15:37
10:13
My charge 3 has developed a series of vertical lines down the screen. They move to different places when I switch screens. I've tried resetting it and changing the clock but nothing seems to work. Any advice would be appreciated!
10-10-2020 07:03
10-10-2020 07:03
Hi @Emmamamo, welcome to our Fitbit Community! I'd like to follow up and help you with your Charge 3 since it developed vertical lines on the screen. By the way, thank you for trying to get this issue resolved before contacting our forums.
I'd like you to try one more workaround which has been helpful for this type of issues. Please try a long restart. To do so on your device, follow the steps below:
Keep me posted on the outcome.
Best Answer10-10-2020 11:12
10-10-2020 11:12
Hi @JuanJoFitbit,
Thanks for the advice. I've tried it several times and unfortunately there's been no change, just lots of lines still. What can I do now please? Thanks!
Best Answer10-10-2020 11:48
10-10-2020 11:48
Does not help here.... 😢
Best Answer10-12-2020 09:24
10-12-2020 09:24
Hi @Emmamamo, thank you for getting back and trying the recommended troubleshooting steps. Since the issue persists, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
@Roosvdh, thank you for joining us in this thread and our Fitbit Community. Regarding the white lines that your Charge 3 is also displaying, thank you for trying the long restart process shared above.
Please restart your Charge 3 as described in this help article. After this, try changing the clock face to one developed by Fitbit, not a third party clock face and see if the lines disappear.
Let me know how it goes.
Best Answer10-13-2020 13:07
10-13-2020 13:07
Tried, doesn't work
Fitbit updated aswell does not help
Best Answer10-13-2020 13:24
10-13-2020 13:24
Having the exact same issue. Occurred right after I took mine off the charger. Seems to be a screen hardware issue as it's persistent no matter what face is showing. Not sure what else to try or if it's salvageable.
Best Answer10-13-2020 15:19
10-13-2020 15:19
I'm having a similar issue, but attempts to do the long restart fail. The progress bar only goes about 20% across, and the screen switches to a smiley face with a single vibration. What can I do from there?
Best Answer10-13-2020 16:42
10-13-2020 16:42
I’m having a similar issue and battery life has deteriorated. Won’t stay charged. I have tried all suggestions listed. Need help or a replacement Fitbit.
