Charge 3 sleep information incomplete
My Charge 3 is 31/2 months old, first 3 nights worked perfectly in sleep mode since then it is telling me I sleep for only 1. 1/2 hours a night.
Last night went to bed at 22-30 awoke at 05-15 Fitbit is telling me I slept for 1.3/4 of an hour. Anybody any advice?
Bazza6695
1 REPLY 1
It's great to see you around, @bazza6695.
If your tracker isn't tracking your sleep information properly, I recommend trying the following:
  1. Make sure to not take off your tracker during the night.
  2. Do you remember being awake during the night? If yes, that solves it! Keep in mind that your tracker will detect if you are awake and will stop the sleep tracking process. If no, proceed to step three.
  3. Restart the tracker. See instructions in the help article: How do I restart my Fitbit device?.
  4. Confirm that the tracker is snug on your wrist (with an HR tracker, the lights shouldn't be visible).
  5. Try sleeping with the tracker on your non-dominant hand.
  6. If the setting was set to sensitive, please switch it to normal.
  7. If steps 1-6 do not solve the issue, I suggest manually editing the sleep log to reflect the time slept. See instructions in the article: How do I edit my sleep history in the Fitbit app?.​
Let me know the outcome. 🙂
