01-15-2019 21:57 - last edited on 09-13-2021 11:54 by LiliyaFitbit
My fitbit charge3 says that "sleep not tracked", but all other metrics are tracked. However, when I checked the app, yes indeed it tracks my sleep including the stages. I have read some forums that it need to capture the heart rate so I gave it sometime. Now it has been 2 weeks and it still shows "sleep not tracked" though I know that it works normally in the mobile app. Please advise how to fix this error on the device, as I dont want to grab my phone just to check the sleep tracker. Thanks a lot fitbit peeps!
01-16-2019 11:09
01-16-2019 11:09
@fitn00bie, welcome on board! The tracker will show this message until you sync it with the phone. Sleep data should go through Fitbit servers where it gets processed to show sleep stages in the app. After that your tracker should display hrs slept instead of 'sleep not tracked' message. All the best!
01-24-2019 22:40
01-24-2019 22:40
What @fitn00bie is saying is that even after the data is uploaded and processed and shows in the app, the tracker still shows "Sleep not tracked." I'm having the same issue as are tons of other people in this forum. Would be nice to hear from Fitbit on this since they've previously mentioned in the forums that it's a known bug.
01-25-2019 15:42
01-25-2019 15:42
Yes that is right, after sync it shows all the metrics to the Fitbit app. Just annoying that it shows sleep not tracked in the watch. Tried the solution they say in other forums by restarting the watch or "begin sleep now"; but still didn't show in the watch. Hope Fitbit address this issue/bug.
01-25-2019 18:23
01-25-2019 18:23
Yes, this worked for me!
Best Answer06-23-2019 11:02
06-23-2019 11:02
Not working..... Still reading "sleep not tracked". Yet appears on my app.
01-02-2020 20:13
01-02-2020 20:13
Mine is doing this also. Worked fine tracking sleep on watch until today. Tried everything and no luck. Sleep shows on the app just not on the watch.
01-02-2020 20:15
01-02-2020 20:15
Is there a fix for sleep being on the app but not showing on the watch? Was working fine until today.
01-02-2020 23:15
01-02-2020 23:15
I didn't find a solution, thus returned it to shop and moved to amazfit bip 😁
01-03-2020 13:44
01-03-2020 13:44
Ready to return mine also. Was on Fitbit chat room for 45 min
She was so far ahead of me I was totally lost trying to follow her instructions. After 45 min the connection was cut off so I gave up. p.
01-03-2020 14:23
01-03-2020 14:23
This happens to me also on a previous occasion when this was happening and fit but could not give me any answers they sent me a new fit bit charge three.
It was only a couple of months later my new fit bit charge three started doing the same thing.
Example being when I wake up in the morning and reset my Fitbit it says that my sleep is not tracked however when I manually enter my sleep time into the Fitbit app on my phone and then calculate the correct sleep times I’ve been asleep.
There seems to be a glitch in the software that is When I wake up in the morning and I reset my Fitbit to the phone it shows of my sleep has not been tracked however when I manually enter the sleep it shows the different stages of the polite and REM sleep and the length of sleep with the school so therefore I don’t believe the fit bit is not tracking sleep I believe there is a glitch in the software that allows the fit bit into auto Track my sleep.
I have raised this with fit bit on more than one occasion and consistently seem to get fobbed around now I’m starting to see other people posting the same thing.
In all honesty I think the charge for a fit bit is a let down I used to charge to HR for a long time and never had any problems at all so as far as a fit bit free sounds it might be time to go to Garman and see what they have on offer
excuse the spelling mistakes but I don’t particularly care because I’m voice typing and you get what I mean anyway.
michael
01-03-2020 15:09
01-03-2020 15:09
01-03-2020 19:07
01-03-2020 19:07
Same thing happens for me sometimes. You just have to sync it, and then wait about 10 minutes. Eventually it should show up though.
01-03-2020 19:23
01-03-2020 19:23
01-12-2020 04:08
01-12-2020 04:08
Same problem. Have had my Charge 3 for over a year. Sleep and water consumed have never displayed on the device ... only on the app or online dashboard. To the Fitbit folks monitoring this forum — I would think that this should be a reasonably easy fix to the software on the device. Why hasn’t that been done? Or, why can’t you provide a good answer to the posts on this topic??
01-22-2020 04:02 - last edited on 02-20-2020 15:22 by LiliyaFitbit
Yes I hear you. The last time this happened after badgering them for a few weeks they sent a replacement Fitbit however it wasn’t long before I had the same issues. God already knows i have enough of my own and now Fitbit want to give me more 😂😂😂
Sent from my iPad
08-13-2020 22:08
08-13-2020 22:08
I am having a similar experience but on my Charge 4. It was showing up on my Charge 4 for the first 2 days then stopped, but when checking the app, the sleep data was being recorded. My phone is an Android phone, but decided to pair the Charge 4 to my iPad to see if it would fix the problem and after I did, the sleep data was showing up on my Charge 4.
My problem only seems to be happening when connected to my Android phone. I went to set it up on my Android phone again and the sleep data was showing "sleep not tracked" on the my Charge 4. I went to my bluetooth settings on my Android phone and unpaired "Charge 4" and then the sleep data was showing up on my fitness tracker. My problem only seems to occur when connected to my Android phone, though the sleep data on the app is showing up, it doesnt show on my device.
08-14-2020 06:37
08-14-2020 06:37
Still not showing on tracker. Shows in app.
09-12-2021 21:10
09-12-2021 21:10
Same problem now. How did you fix it?
