02-05-2020
21:03
15:05
02-05-2020
21:03
15:05
The Charge 3 randomly doubles the readings. For example, 11000 steps will show on the screen as 22000. I have observed this with the step count and the heart rate. When I synchronize the Fitbit with my Windows 10 computer, the readings return to what they should be.
This has now happened with two Charge 3 devices. I returned the first, because the malfunction happened frequently within the first week of owning it. Today marks the first time I have observed this with the second device, which I have been using for about 3 weeks. If the history of the first device is any indication, the problem will grow worse over the next several days.
My device is up-to-date. Are the cause and fix known?
02-06-2020
04:00
07:47
02-06-2020
04:00
07:47
Welcome to the Community, @TeaUser.
Are you manually logging any type of activity that might be doubling your information? If you are, I recommend deleting those activities and see if your information goes back to normal.
I hope to hear from you soon. 🙂
Best Answer02-06-2020 06:55
02-06-2020 06:55
06:43
07:25
02-09-2020
06:43
07:25
Thanks for the update and the information, @TeaUser. I am sorry to hear that you returned the unit. If in the future, there is anything we can help you with, do not hesitate to post it.
Happy stepping.
Best Answer04-01-2020 03:32
04-01-2020 03:32
Thanks for logging this issue as it just happened to me and I had no idea what was going on. I saw your summary and as you say, it fixed itself once I synchronised with Windows 10 which had the correct info on it the whole time. I have had my device for 3 months and just love it. I hope this is not a bad omen!
