01-30-2020
11:26
17:16
01-30-2020
11:26
17:16
I previously had the Charge 2 and used to do over 10,000 steps a day, I've since got the Charge 3 and not even managing 5,000 steps and I'm doing the same amount of activity. I've restarted the tracker and its still the same. Any ideas?
Thanks
01-30-2020 11:39
01-30-2020 11:39
Hi @Annabellax and welcome to the forums. Thanks for trouble shooting and restarting your device. A couple things to check:
If you had to make any changes while trying out these tips, restart you Charge 3 again, but do it twice. Please let us know hoe it works out.
Best Answer01-31-2020 16:22
01-31-2020 16:22
Welcome to the Community, @Annabellax and @SunsetRunner, thanks for the input.
I appreciate all the efforts in trying to fix this accuracy issue. For tips about improving accuracy, I recommend checking the help article: How accurate are Fitbit devices?.
Several things can affect the number of steps your Fitbit device records, including where you place the device, if you wear it on your dominant or non-dominant hand, and your stride length. If you're pushing a stroller or shopping cart, try putting your device in your pocket or use GPS to record your activity, if possible.
If it still seems like your device is undercounting or overcounting steps, try a step test. While you perform your step test, make sure you:
-Walk at a normal pace
-Don’t hold anything in your hands
-Put your arms down at your sides, swinging naturally
-Count 1 step for each foot
-To avoid getting an additional step when you bring your feet together, after you reach 100 steps:
Here’s the step test:
Let me know the outcome. 🙂
