04-17-2019
19:56
11:08
04-17-2019
19:56
11:08
My heart rate function suddenly stopped 2 nights ago and will no longer register any heart rate.
06-16-2020
23:35
05:06
JuanJoFitbit
06-16-2020
23:35
05:06
JuanJoFitbit
Thank you I'll try.
Oh no wish we luck!
Moderator edit: merged reply
06-17-2020 00:49
06-17-2020 00:49
Could someone please help me with the same issue. I posted a few times yesterday but have had no response.
The hr monitor is no longer working. The green lights are not on.
It has stopped entirely. I have tried every suggestion so far loggebdonnthis post, plus a few more and have nad no luck.
And on restarting the watch whilst attached to charger, since the screen came back on it has even more black lines across it!
The screen is also too dim to see in daylight outside but that's irrelevant if I can't get the hr to work as it then become useless.
Could someone please advise.
06-25-2020 12:34
06-25-2020 12:34
I've tried everything on these forums to fix the no heart rate issue and there is no green light blinking on the back of my fitbit. Was fine all day yesterday, but the heart rate is not working and it is not tracking the 250 steps per hour either. On the app it does show my total steps, but no heart rate there either.
07-01-2020 18:58
07-01-2020 18:58
tried all this still not recording trends
07-01-2020 19:07
07-01-2020 19:07
07-02-2020 19:31
07-02-2020 19:31
My heart rate on my Charge3 stopped working yesterday. As a result, it also will not track my sleep. I noticed the green LEDs stopped flashiing, as well. I have reset my device several times with the charger cable. I tried the reboot instructions, but nothing works. I checked my settings, and heart rate is set to "on". Also, there are 2 dead stripes on the display - one across the top and one across the bottom. This occurred at the same time the heart rate stopped working. Resetting the device did not help that either. All other functions seem to be working normally.
07-05-2020 11:07
07-05-2020 11:07
Hi, I really wish the reboot after making sure the HR is turned on, worked, but alas I am still frustrated with this particular fitbit. I have had 3 fitbits which worked perfectly and I gave them to others each time I got a new one and 2 are still in use and working perfectly! However, this one, a Charge 3 limited edition, bought for $170, just 18 months ago, is driving me insane. I suddenly began having no HR and no power after a day. .
Same watch, same band, same person - has worked perfectly until now. HR not recording, and power gone in a day. No changes were made on the app or setting prior to this change. This fitbit has been taken care of impeccably, no water, no damage, etc.
If you can, please suggest something I haven't tried. Looking forward to your suggestions.
Thank you in advance.
e
07-06-2020 21:46
07-06-2020 21:46
These suggested steps didn’t work for me. Not only is the heart rate not being measured which means there is no sleep data, but the green light on the inside of the device is not consistently shining and the red light is on. I got the Charge 3 on November 30 last year and it worked well for two months until the battery needed charging more and more frequently finally losing its charge within a couple of hours. After many calls and trials, it was replaced on April 4, 2020. It’s worked fine until two days ago (3 months) when the heart rate (and the sleep score) functions stopped working.
07-07-2020 15:40
07-07-2020 15:40
07-10-2020 09:14
07-10-2020 09:14
My heart rate is no longer working either. Also there are dark lines across the display and the Fitbit is not holding a charge for long. I tried all the suggestions. Thanks.
07-22-2020 11:27
07-22-2020 11:27
Did you ever get your Charge 3 working, my is doing the same things, I've tried all the suggestions, no green light, no tracking of sleep or heart rate?
07-22-2020 15:55
07-22-2020 15:55
07-22-2020 16:00
07-22-2020 16:00
08-03-2020 20:53
08-03-2020 20:53
08-04-2020 05:07 - last edited on 08-17-2020 19:59 by LiliyaFitbit
Hi,
Go to fitbit.com/support and call to request assistance. Your Fitbit may not be under warranty any longer in which case you’re out of luck.
08-04-2020 05:17
08-04-2020 05:17
my HR is also not working for a week now. I have tried the reboot, it is totally charged. i have turned it on and off as well
Please advise
08-16-2020 21:32
08-16-2020 21:32
I'm currently facing the same problem as you are and I'm not sure what to do, is there a proper way that I can fix this issue? because I don't think it was really addressed here.
08-17-2020 09:12
08-17-2020 09:12
It is very frustrating, I know it was from a software update but Fitbit refuses or is unable to fix the problem. Very disappointed with this watch. I bought it fir swimming and only for swimming and it no longer is of any value to me.
08-17-2020 18:37
08-17-2020 18:37
(Charge 3) I am also having a similar issue. No flashing green light in back, no heart rate recording. I have attempted the suggested steps of restarting the device from the charge cable as well as rebooting from the setting menu. Also double-checked that it wasn't as simple as not turning on heart rate monitor. Have attempted multiple restarts/reboots but the green flashy light remains elusive. Any additional advice would be greatly appreciated. Thank you!
08-17-2020 19:10
08-17-2020 19:10
I wish I had some advice. I tried contacting fitbit, even wrote to the ceo... nothing back. Had to buy a new one. Sad.
