09-23-2021
13:35
15:03
CindyMFitbit
09-23-2021
13:35
15:03
CindyMFitbit
I have been very careful about water and cleaning. Yet just after one year it started to short out. It started with buzzing all the time, screen frantically changing, and the red light constantly staying on. It was unresponsive to squeezing. First it would function while charging, now nothing. Going to put it into rice and pray that works. It was never submerged yet was supposed to handle swimming?! Anyone else have a very short life with theirs?
09-23-2021 15:08 - edited 09-23-2021 15:08
@NutriMom Welcome! It's great to see you around.
Thank you for the detailed information and for the troubleshooting steps you've tried prior to posting.
Please note that the Charge 3 is water-resistant to 50 meters. They're designed to be swimproof and stand up to even the sweatiest of workouts. See the table below and our user manuals for specifics as to whether your device is swimproof or splashproof, but if your Charge 3 isn't turning on even after you plugged in to charge, I recommend visiting this help article: Why isn't my Fitbit device's battery charging? It's probably that now it is refusing to charge.
If that doesn't work, please make sure that you tried to restart it by following these specific instructions: How do I restart my Fitbit device? If this doesn't help, you can also try to perform a long restart. A long restart is different than the normal restart and you can complete the process by following these steps:
Hope this helps.
Best Answer10-01-2021 10:43
10-01-2021 10:43
Thank you for your suggestions unfortunately neither of these options worked. The screen will come on and charge when plugged in but it does nothing if you take it off the charger.
Best Answer10-03-2021 08:37
10-03-2021 08:37
@NutriMom Thanks for your response and for trying the suggested instructions.
I'm sorry to hear that the inconvenience has persisted, my best recommendation is contact our Support Team so they can look deeper into the issue and help you with this matter. You can contact them through chat or over the phone. Click here to get connected. Make sure to mention the steps you've followed, so they can help you from there.
See you around.
