01-09-2019
16:45
13:05
01-09-2019
16:45
13:05
A text message is stuck on my Fitbit screen. I cannot clear the message. The Fitbit also will not connect to my phone.
01-09-2019 17:22
01-09-2019 17:22
Did you try to reboot the device? Instructions can be found here.
Like any electronic device, Charge 3 can experience some software glitches - rebooting the device is the first option to try...
01-09-2019 17:22
01-09-2019 17:22
01-10-2019
07:06
07:09
01-10-2019
07:06
07:09
A warm welcome to the Community @KB14 and @RiseAndShine thanks for the input.
I am glad to see here that the issue with your tracker being stuck has been resolved. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up! ![]()
Best Answer11-29-2019 19:37
11-29-2019 19:37
Your advice helped me as well. Thank you.
04:56
07:09
12-01-2019
04:56
07:09
Welcome to the Forums, @TLCC.
I am glad to hear that the instructions provided in this thread worked and that your tracker is now working properly. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping! 😉
Best Answer03-10-2020 09:22 - edited 04-08-2020 10:44
My device is also stuck on the message screen, but it also won't reboot. It's a Charge 3. I've looked up how to reboot it and tried multiple different suggested ways to no avail. So it won't reboot, but it's also stuck on this message
Edit: well I got the screen to reset by changing the clock face. Unfortunately about a week later, the screen went completely black and hasn't changed since. It still works to record things, but it's useless as a display for anything.
Best Answer07-15-2020 12:37
07-15-2020 12:37
Hi, so I have rebooted and started all over again twice but the screen is still stuck on the message and the option to clear, mark as read and delete is not responding either. I could wait for the battery to die out but its on 75% so will take awhile. Do you have anymore suggestions??
Best Answer07-21-2020 10:20
07-21-2020 10:20
Money is doing the same and wouldnt reboot. I've changed the clockface and it seems to be working again.
