11-06-2018 00:12 - last edited on 11-17-2020 15:03 by MatthewFitbit
Hello, I've tried to update my Charge 3 with todays prompt for an update in my phone app.
The Screen is stuck on 1/3 progress bar, and the charge wont communicate to either Android, iPhone or PC to continue.
Can this be reset, or has it been broken by the update?
11-13-2018 04:21
11-13-2018 04:21
After various attempts on different platforms (iOS, Android, Windows) I gave up and waited.
Waited 3 days and re-attempted on Sunday and it went through without issue.
I'd guess that the update was modified at the Fitbit end to fix the issues.
11-06-2018 00:46
11-06-2018 00:46
Fitbit offer this advice for those of us having trouble updating out Charge 3:
"TROUBLE UPDATING?
If you run into any trouble updating your Charge 3, we recommend the following:
Still having trouble? You can reach our Customer Support team for additional help. "
taken from: https://community.fitbit.com/t5/Charge-3/Charge-3-Firmware-Release-1-44-33/td-p/3042257
11-06-2018 00:59
11-06-2018 00:59
As an update to this....
If I wait 45 minutes - the Charge 3 resets and goes back to how it was (now at least working)
If I try and re-update (from the PC) it doesn't connect to the Charge.
I think I'll wait a few days before trying again in the hope the process improves.....
11-06-2018 03:15
11-06-2018 03:15
Sounds familiar.. mine is stuck since 4 hrs..... wifi , Bluetooth are on, Charge en Android phone fully charged....
11-06-2018 05:56
11-06-2018 05:56
Welcome to the Community Forums @wen7213 and @thinman21! Thanks for sharing those details in regards to what you both are experiencing when trying to complete the firmware update on your Charge 3.
Can you please try every single step that @SteveH shared in this post? If while doing any of those steps you face with any trouble or error message either on the app or tracker, let us know what it says.
We'll be around waiting for your reply.
11-06-2018 06:08
11-06-2018 06:08
Hello,
After restarting my device and the fitbit it took another hour but it's updated !!!!
11-06-2018 06:17
11-06-2018 06:17
I reset the watch twice, the phone once. Charging watch and the phone. Forgot the Charge 3 on Fitbit and Bluetooth. Now when I try to add back the Charge 3 device to Fitbit app, it just blinks back to the Account page. Now what?
11-06-2018 12:11
11-06-2018 12:11
I have done the steps from above and it still won't work. I have been trying for about 2 hours.
11-06-2018 12:24
11-06-2018 12:24
Six hours later and my Charge 3 still won't add back to my account.
11-07-2018 10:12
11-07-2018 10:12
Returning mine today - wasted hours trying all the fixes - seems the firmware update is messing things up.
11-07-2018 10:56
11-07-2018 10:56
After charging both fully, I deleted everything related to Fitbit off my phone. I deleted everything off the Charge 3. Rebooted my phone, rebooted the Charge 3. Added app back like I was a new user, added the Charge 3 to my account, installed update (with both on chargers even though full, and touching each other), and over an hour later it was fixed. I lost a whole day/night's data in the process, but my account retrieved the rest.
11-13-2018 04:21
11-13-2018 04:21
12-27-2018 07:48
12-27-2018 07:48
I don't know if you had any luck, but I'm on try #7, charger attached to the macbook, app open on phone and it gets 1/3 of the way and resets after 30 minutes of "updating". Did you ever figure out how to get your update to complete?
12-27-2018 07:52 - last edited on 03-13-2020 19:17 by LiliyaFitbit
returned it never worked after the firmware update
12-28-2018 12:17
12-28-2018 12:17
04-06-2019 07:55
04-06-2019 07:55
This is not a solution.
04-06-2019 07:57
04-06-2019 07:57
How can your company get away with shipping a product that requires a firmware update immediately upon delivery, while not having a solid method of pushing that firmware to the device. How is this still a thing?
04-30-2019 02:56
04-30-2019 02:56
I performed an update last night (Apr 29 2019). The message indicated up to 30 mins., so I watched some TV for an hr. Checked and it was at 30% and was concerned it had frozen so started to look for help. In the end, I decided to leave it overnight and it had completed by the time I checked this morning. That was an 8 hr gap so I assume it probably took at maybe 3 hrs. to complete? 30% = 1hr, 100% =3.33 hrs.?
In summary ... easier to try and leave it overnight (phone and fitbit plugged in and charging) rather than do the reset, forget bluetooth etc. I find that a bit of a pain.
06-02-2019 03:51
06-02-2019 03:51
So just wait? mine is stuck for 5 hours now, I can't reset it with the button.
How can I reset?
06-05-2019 18:55
06-05-2019 18:55
Same problem for me. Can't reset fitbit. Nothing responds. Can't remove the fitbit....says it is updating. Very frustrating.
