02-01-2019
23:34
11:25
02-01-2019
23:34
11:25
New from the box Charge 3 (a replacement for the previous one that had sync issues) connected ok and wanted a firmware update straight away. It is now stuck in this update with the line at about 75%, has been at this point for 12 hours now. Internet’s fine.
I tried to restart it (connected through charger, as per instructions), it wouldn’t restart. Nothing’s happening on the screen, the update line remains the same.
It won’t even buzz or vibrate on connection.
Dead as a dodo...
02-02-2019 07:41
02-02-2019 07:41
Welcome on board @DrBunny! Sorry to hear about the inconveniences you've been having with your new Charge 3. Thanks for already troubleshooting this, nice way to go!
We recommend start charging your device before updating it, since updates can take several minutes to an hour and are demanding on the battery. Note that if you update your device at midnight (when your step count resets) you may see an inaccurate step count for 24 hours.
Make sure your tracker is charged and then try these steps:
Note that if you get notifications from your mobile device on your tracker, before you can use a different device or computer you need to follow the instructions in Why is my tracker only syncing with one mobile device?
Give this a shot and let me know the outcome!
Best Answer02-02-2019 07:41
02-02-2019 07:41
Best Answer12-20-2019 16:34
12-20-2019 16:34
This worked ... Thanks 🙂
Best Answer02-04-2020 02:01
02-04-2020 02:01
This fix is not working. My Charge 3 will NOT restart. I’ve tried about 50 times now. Just stays at 75% on the update bar.
Best Answer08-18-2020 08:18
08-18-2020 08:18
My brand new out of the box charge 3 is doing the exact same. Was going through the update and the bar didn't move for around an hour or so, it won't restart and I've tried all of the 'fixes' but nothing is working. Anyone got any ideas what I can do? The only thing I can think of is waiting for the battery to die and hope that this resets it for me?! So frustrating!
Best Answer09-12-2020 20:27
09-12-2020 20:27
Garbage answer. Still fails and this has been a known issue for a year now. How about we all just take them back and buy a Garmin?
