04-11-2023 03:39
04-11-2023 03:39
My Charge 3 screen is too dim to read anything. I have tried changing settings, I have deleted & reinstalled the app. I have disconnected and re added the device to the app and nothing works. I haven’t been able to wear it in over a year and am about to bin it unless someone can help.
05-03-2023 10:30 - edited 05-03-2023 10:30
Hello everybody!
Thanks for reaching out regarding this situation with the Charge 3. In this case, please be so kind to contact and report this directly with Fitbit Customer Support. They will help you out! We will be closing this thread, there will be no option for future replies.
04-14-2023 09:32
04-14-2023 09:32
Welcome to the Fitbit Community, @mag52. I'm sorry to hear your Charge 3 screen is too dim. Thank you for mentioning the steps that you have followed to resolve this.
Please try restarting your tracker:
04-14-2023 11:32
04-14-2023 11:32
I tried everything including the steps you mentioned and it’s still dim. This is my second Fitbit and I encountered the same issue with the first one so I bought another one thinking the first one was an isolated case. It sounds like it’s a common problem 😞
04-14-2023 11:44
04-14-2023 11:44
Welcome to our community, @Ameeg. Thank you for letting me know that you have tried everything.
I understand how frustrating this could be and could you please confirm that you have tried restarting your Charge 3 using the 15-second method:
04-14-2023 12:54
04-14-2023 12:54
Tried it and still dim 😞
04-14-2023 13:24
04-14-2023 13:24
Thanks for getting back to us and I'm sorry to hear that your Charge 3 is still dim @Ameeg.,
Have you tried changing your trackers clock face with the instructions of: How do I change the clock face on my Fitbit device?
04-14-2023 14:57
04-14-2023 14:57
I am having the same issues with my charge 4 and have tried all these reboots. Screen is so dim can only read it some in extreme dark.
04-14-2023 15:24
04-14-2023 15:24
Changed the clock face and didn’t help 😞
04-14-2023 15:45
04-14-2023 15:45
Welcome to the Fitbit Community, @Tirosh, and thanks for getting back to us @Ameeg. I'm sorry that you aren't able to lighten more your Charge 3 and Charge 4 screens after following advised troubleshooting steps.
Could you please confirm that your devices are not on DND (do not disturb) or Sleep mode?
04-14-2023 15:50 - last edited on 04-14-2023 16:08 by AndreaFitbit
yes not on dnd, top and bottom of screen can sort of be seen, but not the sides. Not sleep mode either
Moderator edit: updated post.
04-14-2023 15:54
04-14-2023 15:54
Screen failure, seems fitbit needs to address this apparent system issue
04-14-2023 16:00
04-14-2023 16:00
It’s neither on DND nor sleep mode
04-14-2023 16:13
04-14-2023 16:13
Started 2 weeks ago and getting worse
04-14-2023 16:22
04-14-2023 16:22
04-14-2023 16:50
04-14-2023 16:50
Only able to look into warranty, but otherwise not able to get any help. Since so many people have this issue fitbit needs to make a correction or customers like myself need to go with another tracker company
04-15-2023 01:56 - last edited on 04-28-2023 09:28 by DavideFitbit
Thank you Andrea but I’ve tried this now and I can’t see what is on the screen, if there is anything. It’s vibrating ok but I’ve no idea now whether it’s on or off.
Yep done that. No change.
04-15-2023 06:35
04-15-2023 06:35
I didn’t get in touch with the Support Team. I only posted the issue here in the forum. Like others, I’ll look into getting a different kind/brand of tracker considering that I’ve had 2 Fitbits with the same issue.
04-15-2023 07:38
04-15-2023 07:38
Yes I changed the clock face several times and nothing makes any difference.
04-15-2023 09:16
04-15-2023 09:16
Thanks for getting back to us @Tirosh, @Ameeg and @mag52. Let's keep on working on this.
@Tirosh, I understand that this can be very frustrating, your feedback and comments are greatly appreciated.
@Ameeg, thank you for the clarification. I went ahead and created a case on your behalf.
@mag52, I also created a case for you.
You can check your email.
04-15-2023 09:47 - last edited on 04-28-2023 09:31 by DavideFitbit
Same thing for my charge 3. Happened to a previous Charge 3 and replaced the old one last Christmas. now he "new" one is is so dim after charging it I cant read anything. It is only 6 mos old. I am not hard on my equipment at all., very disappointing.
ms
I too have had the exact same MO and did all of the resets suggested. replaced my first charge 3 with another thinking it was a "one off" but have a repeat issue in a much shorter time of owning this charge 3. disappointing.
ms62
