06-19-2019
17:29
10:58
06-19-2019
17:29
10:58
I find the Charge 2 had a darker screen, the 3 I can barely read it, in fact never try, just grab my phone to read the time and steps
10-31-2020 21:40
10-31-2020 21:40
My charge 3 got dimmer and dimmer and died. Called support but they said my charge 3 is out of warranty. It's older than 1 year. Nothing they can do but please consider buying another Fitbit. We make poor quality devices and also can't help you much. Please buy more poor quality devices from us.
11-01-2020 08:54
11-01-2020 08:54
It’s so dim I can’t read the **ahem** screens to see the options! What a piece of crap
Best Answer11-01-2020 09:04
11-01-2020 09:04
Best Answer11-01-2020 12:31
11-01-2020 12:31
11-01-2020 13:03
11-01-2020 13:03
Best Answer11-11-2020 14:21
11-11-2020 14:21
I have restarted my Fitbit Charge 3 numerous times, set the brightness on Auto and Normal and it is to dim to read even indoors. Reading it outdoors is completely impossible. Fitbit will not replace it, I can't return it so I just flushed $150 down the toilet. I will never purchase a fitbit again. I'm throwing in the towel and moving to an apple watch.
11-11-2020 14:53
11-11-2020 14:53
best solution is to buy a garmin
Best Answer01-19-2021 10:15
01-19-2021 10:15
Worked perfectly!! Thanks.
Best Answer04-20-2021 07:27
04-20-2021 07:27
Hi Anita have you tried changing clock face in App setting there are lots to choose from.
I am having dim issue too, screen too dark to read settings.
Best Answer04-24-2021 09:56
04-24-2021 09:56
I absolutely loved my Charge 3 until it went dim. It’s impossible to see the time outdoors and any room indoors with a lot of light. I’ve never gotten it wet even though it’s supposed to be water resistant, and I can’t believe all these people have the same problem and this company is leaving us all out to dry. Is there seriously no real fix for this other then the “go buy another one” line?
05-08-2021 16:17
05-08-2021 16:17
I know how to adjust this setting but, still, it's not bright enough unless it's dark outside.
Best Answer05-10-2021 05:16 - edited 05-10-2021 05:17
Hello everyone. @tracy4949, @SamJF, @chupika130. Welcome to the community forums. @tracy4949 Thanks for your great input.
I'm very sorry for the experience and thank you so much for the troubleshooting steps you've tried and for taking the time to provide your feedback. If the troubleshooting steps suggested in this thread haven't helped, my best recommendation is that you please contact our Support Team for further assistance. They will be able to look into your cases and provide a prompt resolution.
Note that you can contact them through chat or over the phone and you can click here to get connected. On a side note, please consider that replacement devices are provided for products that are within the warranty period. If your original Charge 3 is no longer under warranty a discount could be an available option but some conditions and requirements should be met. For more information about our warranty policy, I recommend visiting the following link: https://www.fitbit.com/global/us/legal/returns-and-warranty.
See you around.
Best Answer05-10-2021 07:36
05-10-2021 07:36
Best Answer05-10-2021 08:00
05-10-2021 08:00
@SamJF Thank you for your reply.
I understand how you are feeling and I appreciate the feedback provided. Our team strives to improve our products and the feedback shared by our members is a big part of that process as it helps to continue working on improvements to our services too. Thanks for your patience.
See you around.
Best Answer05-10-2021 17:34
05-10-2021 17:34
Thanks for this answer!!
Best Answer05-11-2021 08:27
05-11-2021 08:27
Had the same frustration. Thankfully it was under warranty. They replaced it. Also fortunate that they sent two replacements. One of the two replacements died w/in a few months; same screen problem as the first Charge 3.
I figured out it must be that I was showering with it. Now I take it off and that seems to be helping.
05-11-2021 08:33
05-11-2021 08:33
Best Answer05-11-2021 12:47
05-11-2021 12:47
Best Answer05-13-2021 09:06
05-13-2021 09:06
Hello @Skyegrigsby, @Spagball, @chupika130, @SamJF. Welcome to the community forums. @Spagball Thanks for your input.
Thank you for taking the time to provide your feedback. I'd like to let you know that Fitbit products are covered under 1 year of warranty from the date of purchase, except that if you reside in the European Economic Area (EEA) and you purchased your Fitbit product in the EEA, the warranty period is two (2) years from the date of purchase (the "New Product Warranty Period").
If you have questions about the warranty, you can visit the link provided on a post above or click here. We really appreciate your feedback and comments since this helps us to keep improving.
See you around.
Best Answer10-12-2021 12:34
10-12-2021 12:34
What part of the statement “the screen is BLACK “ do you not understand? If the screen is black you can’t see what the settings are. Also, you can’t see that you have changed the clock face.
