10-11-2018
07:46
15:06
10-11-2018
07:46
15:06
So I got mine a couple days ago but the touchscreen does not seem to be working. I tried swiping every which way and restarting the device multiple times but still nothing. I even had someone else try it in the event I was doing something incorrectly but still nothing. Tapping on the screen does nothing either. Anyone else having issues with it?
02-08-2019 16:12
02-08-2019 16:12
@Heatherbelle1 wrote:Hi, I’m having the same problem & like you thought it was just me initially. Thought at first it was because my fingers were wet when trying to record a swim, then maybe the screen had sun cream on. Decided to google it & found this....
Poopah
Cannot get back to starting screen on wrist device.
Best Answer02-15-2019 08:45
02-15-2019 08:45
my screen is not working it was vibrating. I put a straight pen in the hole on the side and now it's not doing anything. I tried all of the previous suggestions without success.
Best Answer02-18-2019 20:37
02-18-2019 20:37
@111jenn111@I had the same dilemma as you. I plugged it in and nothing changed. While charging I held the button for a while and the screen went black. I then hit the button again and the smiley face came up. I hit the button once more and then everything was back to norma
Best Answer02-18-2019 20:38
02-18-2019 20:38
Best Answer03-10-2019 00:46
03-10-2019 00:46
I've had my Charge 3 for several months and suddenly the capacitive screen is not responding to anything but the initial tap.
Swiping elicits nothing. I've tried holding the button for 15 seconds while in charger cradle but didn't help 😞
Best Answer03-14-2019 08:42
03-14-2019 08:42
I am having the exact same problem. I cannot swipe left, right, up or down. I have tried turning it off. I have tried a soft restart. I even removed it from the app and re-added. I am very frustrated. What will fix this?
Best Answer03-14-2019 12:15
03-14-2019 12:15
03-22-2019 09:51
03-22-2019 09:51
Thank you so much for your post - I had tried all the hard resets and charging suggestions to make my screen be responsive again and your simple solution of changing the face setting on the app worked!
Best Answer03-27-2019 16:27
03-27-2019 16:27
Hi I have got firbit charge 3 and the screen is not working x I have tried to restart it but it doesn’t work x it only buzz when I press the touch button and nothing else x last time the restart technique worked but not this time 😞 getting really frustrated
Best Answer04-01-2019 14:46
04-01-2019 14:46
Turning off the Bluetooth works! After trying all of the above suggestions, actually turned off my mobile device and used a simple wall USB charger to perform reset and worked flawlessly!!
Best Answer04-03-2019 20:13
04-03-2019 20:13
Getting nowhere. Tried a zillion resets. Wouldn't swipe from the start. Cannot not give this to my 80 year old Dad. It is supposed to help him check his heart. This is frustrating enough to stop it.
Best Answer04-03-2019 20:35
04-03-2019 20:35
Best Answer04-07-2019 06:09
04-07-2019 06:09
I was having the same issue. Tried to do the short and long resets, no response. Changing the clock face with my Fitbit plugged in and then taking it off the charger after the new clock face showed up on my Fitbit worked for me. I’ve had it for a little over 3 months and this is the first time this particular issue has come up for me (there have been plenty of other issues though, still unresolved).
Best Answer04-26-2019 14:04
04-26-2019 14:04
Can someone please help, like the person in this
My Fitbit screen isnt responding have done all the suggested steps. The reset the long reset charging etc with no luck please help this is quite new only gotnin febuary
04-26-2019 15:57
04-26-2019 15:57
Best Answer04-26-2019 16:50
04-26-2019 16:50
Best Answer04-26-2019 17:15
04-26-2019 17:15
04-26-2019 18:58
04-26-2019 18:58
Best Answer04-27-2019 13:09
04-27-2019 13:09
Hi I have tried the reset and my screen is still not responding.
Any other suggestions? Its getting a little frustrating as I like to use my Fitbit to track my weekly gym activities
04-27-2019 13:28
04-27-2019 13:28
I recommend the Garmin vivoactive 3/ 3 music to almost everyone. It has way more activity settings, Vo2 max measurements, onboard gps, with the music edition you get 500 songs worth of storage, can be paired to external sensors and headphones, more accurate HR, abnormal HR detection, and live feed to allow family to watch your race (pace, speed, and location) live. Also has downloadable activities such as jump rope, hike, open water swim, maps, etc and includes workout downloads and golf course downloads. You get all of that for around 50 bucks more than the charge 3 and it works without issues. To all those who keep saying “I’ve already payed for the charge 3”, take it back. Fitbit, bestbuy, and pretty much all other retailers will give a full refund for a defective product. But the choice is yours, keep dealing with tedious Fitbit devices that don’t work, or just go with Garmin. Btw, for all the action camera users (GoPro, Garmin Virb, etc) Garmin devices can usually pair with the cameras to add time stamps and speed stamps and allows you to control the camera from your watch.
