01-22-2022
17:48
07:57
AndreaFitbit
01-22-2022
17:48
07:57
AndreaFitbit
My charge 3 out of nowhere is turning itself on and off again. I have no control. When I turn it on, it turns itself off. When I do nothing, it repeatedly turns it on and off again. Can this be fixed?
Moderator edit: format.
01-24-2022 16:56
01-24-2022 16:56
Welcome to the Fitbit Community, @Splagho.
I'm sorry to hear about the difficulties you experienced with your Fitbit Charge 3. Thank you for the information provided.
In this case, I would recommend restarting your Tracker by following these instructions.
In addition, you can perform a long restart:
Hope this helps.
01-26-2022 04:12
01-26-2022 04:12
I also have the same problem with my Charge 3.
Tried to restart it sevelar times, but nothing changes.
Before connection with charge cable Charge 3 was "dead", after plug-in in started to do something, i done restart. After restart showed 1% of battery, after some seconds there are 100%. When i remove device from the charging cable it works onlu some minutes and then swith off again.
What should i do? How to fix it?
01-26-2022 12:51 - edited 01-27-2022 12:43
Welcome to the Fitbit Community, @DaigaK.
Charging your Fitbit Charge 3 to 100% may take 1-2 hours. If you have leaved your Tracker charging for 2 hours but still continue having difficulties, the best way to get help for this problem is to chat with us online or give us a call. Please click here to get connected.
Have a nice day.
