11-17-2020
01:09
06:43
JuanJoFitbit
11-17-2020
01:09
06:43
JuanJoFitbit
My charge 3 will only work when it is charging. It says it is fully charged but when I disconnect it and put it on my wrist it works for a few seconds then stops. When I connect it to the charger again it says the charge is at 1%. I have rebooted it several times but nothing improves.
11-17-2020 06:43
11-17-2020 06:43
Hi @Anne2020, welcome to our Fitbit Community! I'd like to follow up and help you with your Charge 3 since it won't keep a charge and it turns off when you remove it from the charger.
I'd like you to try a long restart. To do so on your device, follow the steps below:
In case the issue persists after this, try the troubleshooting steps that are listed in this help article. After this, charge your tracker for 2-3 hours and see if the issue gets fixed.
Keep me posted on the outcome.
11-19-2020 09:00
11-19-2020 09:00
11-21-2020 02:37
11-21-2020 02:37
Hi
Thanks for the advice, unfortunately after 2 long restarts and thoroughly cleaning the charger and watch the situation is still the same.
Is there anything else I can try?ANNE
