02-13-2019
15:43
11:25
02-13-2019
15:43
11:25
I just got my Charge 3 today, and when I hooked it up via my phone & app, it said there was an update. So it started applying the update....and it's progressing about a percentage per minute. How long is this update supposed to take? Surely Fitbit has figured out how to transfer data faster than this, right? This isn't gigs and gigs worth of an update is it?
Sure, patience isn't my strongest characteristic....but I'm interested in using this thing today sometime. 😛
09-12-2020 20:25
09-12-2020 20:25
So is this a Charge 3 only problem, or is it happening across the entire product range?
Best Answer09-13-2020 08:08
09-13-2020 08:08
I tried several times updating following carefully the instructions. The updating process stucks in the very begining, waiting for hours doesn't help.
09-13-2020 18:56
09-13-2020 18:56
Good luck ! I updated my charge 3. Now the the heart rate monitor is so off it won’t work correctly any more. Yes I updated this 3 times to see if it would correct. It didn’t Firbjr sent another one never got it. They said it was delivered to me. I asked them for a tracking number never got that either. Horrible customer service. This update was designed so you buy the New Fitbit 4. Please let me know if you have the same issue once you have your update. 3 of my friends did. Thanks and stay safe !
09-20-2020 04:10
09-20-2020 04:10
My Fitbit Charge 3 has been trying to do the firmware update for the last 12 hours...it just isn’t working. Really lousy experience
09-22-2020 06:32
09-22-2020 06:32
I'm completely losing patience with this update! It been over an hour and still isn't updated.
09-22-2020 06:36
09-22-2020 06:36
I got mine to update. Btty life is only a few hours. It will not last overnight, screen becomes randomly un responsive.... I have done the long reset and it still does not operate properly. Still not happy.
Best Answer10-20-2020 13:44
10-20-2020 13:44
If this eternity-long update were the first frustrating difficulty with my Charge 3, I might have some patience. Their chat scheme never responded.
If causing these troubles is a marketing plan to get me to buy a Charge 4, here is my question: does anyone out there know of another fitness tracker that actually works.
Best Answer01-03-2021 12:53
01-03-2021 12:53
Yes, your advice worked for me too. The Versa 3 updated successfully after restarting bluetooth.
