10-10-2021
08:25
10:58
AndreaFitbit
10-10-2021
08:25
10:58
AndreaFitbit
All of a sudden today, my charge 3 started vibrating non-stop and cycling between the clock face screen and the sleep/dnd screen. It won’t let me go to any other screen. I tried doing a hard reset, but that didn’t fix the issue. The time on the screen also looks grainy, like it does when the battery is low, but the battery is at 70%. I tried putting it in the charger, but now the screen won’t turn on at all. I bought it just over a year ago, so I’m very disappointed by this - you’d think it would last longer. Any tips about what is going on?
10-10-2021 08:26
10-10-2021 08:26
And now when I try to do another hard reset, there’s just a constant buzz as I hold down and nothing else happens
10-10-2021 12:28
10-10-2021 12:28
Hi there @Otherxtina.
Thank you for the detailed information and for already trying to resolve the issue. If you've tried to restart your Charge 3 and the inconvenience has persisted, I'd recommend trying to perform a long restart. A long restart is different than the basic one and you can complete it by following the instructions below:
Hope this helps.
Best Answer10-11-2021 11:08
10-11-2021 11:08
I tried this but the issue didn’t resolve. For a period of time there was a 100 and a diamond shape on the screen, and now there’s nothing. It won’t turn on, even though I’ve tried a normal reset and a long reset
10-11-2021 11:49
10-11-2021 11:49
@Otherxtina Thanks for your reply.
I appreciate the additional details shared and for trying the suggested instructions. Since the inconvenience has persisted, my best recommendation is contact our Support Team so they can look deeper into the issue and help you with this matter. You can contact them through chat or over the phone. Click here to get connected. Make sure to mention the steps you've followed, so they can help you from there.
See you around.
Best Answer03-24-2022 12:22
03-24-2022 12:22
This exact thing happened to me today after I washed my hands and a bit of water got under the band. I’ve used this Fitbit in the Pool many times as it’s supposed to be waterproof so idk what happened here. Neither short reset nor long reset work, there is zero response from the device. It vibrated itself to death.
03-25-2022 11:01
03-25-2022 11:01
Welcome to the Fitbit Community, @Christy333. Thank you for letting us know about what happened with your Charge 3 and for trying short and long resets.
Charge 3 is water-resistant to 50 meters. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Keep on visiting the forums.
