02-14-2019
13:20
11:25
02-14-2019
13:20
11:25
Fully charged.....blank screen.....vibrates when button is pushed
11-09-2020 10:32
11-09-2020 10:32
I've tried many things to get it to work but to no avail. It is sad that this issue can't be fixed or the fitbit be replaced. It seems to be a common issue. The device lasts about a year and then goes bad.
11-09-2020 10:38
11-09-2020 10:38
Best Answer11-09-2020 11:20
11-09-2020 11:20
Best Answer11-09-2020 11:32
11-09-2020 11:32
Best Answer11-09-2020 14:26
11-09-2020 14:26
11-28-2020 09:24
11-28-2020 09:24
I have a 21 month old charge 3, have always been able to reset black screen until last week. Screen was fading, did update, screen still faded, then went black. Have changed clock face and restarted multiple times, still black screen, but still tracking steps, sleep. Unfortunately in my attempts to reset the alarm changed to 11PM. There does not seem to be a way to reset it other than on the device, which has a black screen. Calls to Fibit most unsatisfying, offered 35 percent off a new one which is $2.00 less than the current sale price! I was informed several times how many days past the warranty my device was. My reply was a $150 device should not have the ongoing issues that have been reported and is obviously a piece of crap. Loved the device, but am very reluctant to invest any more money on a device with such a short lifespan.
12-13-2020 14:58
12-13-2020 14:58
My Fitbit Charge 3 screen is black. I rebooted it several times. The smiley face appears but I can barely see it. The screen is black as soon as I lift the Fitbit off the charger. I tried changing the clock. After the selection was completed the screen is still black so I can't view the clock. The "initial" problem was the screen had gotten darker. It was hard to see the information. To try and fix that problem, I swiped left on the screen and went to settings to brightness. I barely tapped the screen and it went black. It syncs and collects data.
Best Answer12-29-2020 11:52
12-29-2020 11:52
My fitbit has the same issue - black screen, vibrates when I press the button but does not do anything else. It will not sync and no updates appear to be available via the app. I have tried a reset, as described, but simply get a single line, then a smiley face but the screen remains blank. I cannot change the clock face at it will not sync. Please can someone from fitbit contact me via email with advice on a way forward. I'm hugely disappointed that this has happened.
Best Answer12-29-2020 12:35
12-29-2020 12:35
Best Answer01-06-2021 07:44
01-06-2021 07:44
Hi there, my Fitbit vibrates but has a blank screen. It syncs to the app and is still showing my stats when synced so it seems to be working fine but for the blank screen. I have restarted the device while charging and changed the clock face but there has been no improvement. Is there anything else I can try? Thanks in advance
Best Answer01-13-2021 19:50
01-13-2021 19:50
Same issue.
Clock face change fails.
Won't sync.
Unresponsive to button pushes/attempts to restart
No display at all.
Vibrating stops when on charge.
Swaps between a constant vibrate and constant green light on underside or flashing green with "flashing" vibrations.
Best Answer01-13-2021 21:59
01-13-2021 21:59
Hello. I have the same problem. No screen for weeks now. Have tried to reset to no avail and accepred my fate that this was better for me to stop obssesing looking st the screen. But then the non stop vibrating started oast night. I changed the clock face, tried the 15 second reset. Read the threads above and tried the solutions to no avail. Also have a rash from the wrist band but that is a separate issue i can fix. Please help.
01-19-2021
07:38
09:42
DavideFitbit
01-19-2021
07:38
09:42
DavideFitbit
My Fitbit charge 3 has a blank screen, vibrates continuously while pushing the button and plugged in. It also won't sync. I purchased it in 2019 so there's no warranty. Please help.
I've tried restarting it but it doesn't work
03-07-2021 08:49
03-07-2021 08:49
Hello. I have the same problem. No screen for weeks now. Have tried to reset to no avail. Please help as this appears to be a major software issue and very widespread.
03-07-2021 09:01
03-07-2021 09:01
03-07-2021 09:16
03-07-2021 09:16
03-11-2021 05:01
03-11-2021 05:01
Hello everyone.
For screen inconveniences, my best recommendation is to check the following thread for tips and suggestions. IIf troubleshooting doesn't work, as advised on that thread, please reach out to Support for further assistance.
On a side note, thank you very much for taking the time to provide your feedback! Our team is always working to enhance your experience and your feedback is a big part of that process.
See you around.
Best Answer03-11-2021 05:19 - edited 03-11-2021 05:57
Support only will offer you a coupon towards a new unit which is basically worth nothing as the coupon gets the price equal to what you would pay from another retailer. This is clearly a defect that needs to be addressed.
Best Answer03-11-2021 05:43
03-11-2021 05:43
@tajdtj, thank you very much for your reply!
Your feedback is definitely very appreciated! Take into consideration that your comments are very important and they help to continue working on improvements.
Please note that replacement devices are provided for products that have a defect while still in the warranty period. If your device is out of warranty, it can't be replaced but a discount is provided. For more information about our warranty, please click here.
See you around.
Best Answer03-11-2021 07:51
03-11-2021 07:51
Support has confirmed that my Charge 3 is defective since steps to correct (press button while on charger and changing clock face) have not worked. Seems like a overall defect in product design of the Charge 3. They offered a discount on another product due to being just out of warranty.
Hoping the product defect is not also in other FitBit watches/trackers. Loved the product while it worked.
