02-14-2019
13:20
11:25
02-14-2019
13:20
11:25
Fully charged.....blank screen.....vibrates when button is pushed
11-26-2019 11:39
11-26-2019 11:39
Hi there - having the same issues as N1MU. Have tried resetting multiple times. Fitbit is disconnected from my app + will not be found when I try to connect via bluetooth.
Can see the smiley face when connected to charger - vibrates when touch side button - but constant black screen.
Can you help create a case for my device as well?
Thanks,
Best Answer11-26-2019 15:11
11-26-2019 15:11
So I am on my 3rd Fitbit charge 3. Each one has stopped working for one reason or another. I had a Charge 2 and didn’t have any issues. I upgraded to the charge 3 because it claimed to be water resistant as I started to exercise in the pool. So I’ve had nothing but problems since I updraded and it’s only been 5 short months. My current issue is the newest one worked fine for a week then all of a sudden it was tracking but I had no screen. I really don’t want to have to erase my data to do a reset. That’s ridiculous! I did notice in the app in the upper right hand corner it shows a picture of what looks like a ribbon from a typewriter maybe with a pink dot above it. Has anyone with screen issues seen this?
Thanks for any assistance
Best Answer11-26-2019 15:17
11-26-2019 15:17
Best Answer11-26-2019 15:46
11-26-2019 15:46
Hi, no joy resetting, everything shows as working on the app but dead on the screen of the watch
Best Answer12-06-2019 09:08
12-06-2019 09:08
Same issue. I just got a new Fitbit. It vibrates when I push the button but the screen remains black.
I tried to restart it...NOTHING!
Best Answer12-06-2019 09:09
12-06-2019 09:09
12-06-2019 12:42
12-06-2019 12:42
@LRMCG did FitBit replace it or did they judt give you a discount on a new one?
Best Answer12-06-2019 12:51
12-06-2019 12:51
Best Answer12-06-2019 14:50
12-06-2019 14:50
Best Answer01-18-2020 03:24
01-18-2020 03:24
Restarting isn’t working for me, neither is changing the clock face...
Best Answer01-24-2020 13:08
01-24-2020 13:08
Please help!
Fitbit Charge 3 simply does not work, it vibrates when I connect to charger or press button but screen is completely black, tried the reset function various ways but nothing seems to work??
Thanks in advance for any help
01-25-2020 03:10
01-25-2020 03:10
Best Answer01-28-2020 03:20
01-28-2020 03:20
I’ve tried both of these solutions (resets and changing the clock face) and neither have worked for me.
Best Answer02-08-2020 16:30
02-08-2020 16:30
Hey i have same problem. i tried all possibilities but nothing happen because mi phone cant find the device. Some another option?
Regards
Best Answer02-08-2020 18:29
02-08-2020 18:29
I’ve tried all of these ... nothing helps.
Best Answer02-14-2020 18:41
02-14-2020 18:41
This did not work. I'm ready to return my fitbit
Best Answer02-14-2020 18:47
02-14-2020 18:47
Best Answer02-23-2020 04:51
02-23-2020 04:51
My Fitbit charge 3 screen is blank the 4th time. First time I change clockface and it works. 2nd time I change clock face still blank and then I reset is by pressing down the button for 8 seconds and it works.3rd time I try 1 and 2 but does not work so I press for 15 sec, etc. It works. This is the 4th time. Steps 1 through 3 does not work anymore. Any other suggestion?
Best Answer02-23-2020 07:55
02-23-2020 07:55
Hi,
my wife’s Fitbit charge 3 screen has also stopped working but still vibrates. Have made several attempts to reboot as per the guidance and change clock faces but no response on the screen. It was a gift for her in December 2028 (in Uk) but no proof of purchase.
can you help?
Best Answer02-23-2020 08:09
02-23-2020 08:09
I received my new replacement tracker yesterday, after getting in touch with customer service on live chat.
I had to tell them where I bought it from and roughly when. I would just let them know it was a gift - they would be able to check when it was first set up by your wife giving her email address used to create Fitbit acct.
Fingers crossed you get sorted, and fingers crossed mine won't go the same way - 3rd time lucky for me?
