02-14-2019
13:20
11:25
02-14-2019
13:20
11:25
Fully charged.....blank screen.....vibrates when button is pushed
08-19-2020 14:45 - edited 08-19-2020 14:48
08-19-2020 14:53
08-19-2020 14:53
Can you not send them a copy of your bank statement as proof of purchase? Or request a copy of the receipt from the retailer
08-29-2020 12:49 - edited 08-30-2020 06:21
Maybe this will help someone with the black screen, and vibrating issue with the Charge 3.
I tried every reset method I had read of, or watched on Youtube with no luck in getting my screen back. Trying long press resets didn't help, Bluetooth would not find the Charge 3, so unable to change clock faces wouldn't help. My unit was charged to 85% battery life when the issue started, so the battery should not be the issue.
Here is what worked!
After doing a 30 second long press of the unit I placed it on the Fitbit charger, and left it attached for three days. A thin white line appeared horizontally at the middle of the unit and went from the left to the right seeming to become longer with time.
EDIT:
Update! After thinking I was back in business with my Charge 3 I now believe the issue is the battery. after approximately four hours of use the unit requires recharging and this is completely unacceptable. As it appears the Charge 3 is a $150 disposable item, and there is no support for units outside of the warranty period, I will be searching out companies that make a fitness tracker with either user replaceable batteries or repair center battery replacement support. I hope others use of the reset method I wrote out above have better luck with battery life after the screen comes back.
Today (day 3) I noticed the white line had disappeared so I removed the unit from the charger, and did a short press and received the Smiley Face as you see when fully charged. It then displayed the date of Aug 26 which was the day it quit working and the distance I had logged that day.
I did a Bluetooth connect and low and behold it reset to the correct date and went back to working correctly.
It's a process but may save your device!
08-29-2020 15:51
08-29-2020 15:51
Wow Dwight, thanks! I'm hopeful I can get my device back using this method!
08-29-2020 20:33
08-29-2020 20:33
08-30-2020 06:24
08-30-2020 06:24
@Carolezh Please see my update to this issue. The screen may return, but it appears for me the battery is at the end of it's life. I hope your results are better.
08-30-2020 06:25
08-30-2020 06:25
@userinuae Please see my update to this issue. The screen may return, but it appears for me the battery is at the end of it's life. I hope your results are better.
08-31-2020 11:26
08-31-2020 11:26
I've tried resetting my Charge 3 and it doesn't work. When it is plugged in and the button is pushed, it vibrates for about 10 seconds and then stops. My phone will not recognize my Charge 3.
Any ideas?
09-05-2020 15:02
09-05-2020 15:02
My husband's charge 3 has this problem too. It's blank but vibrates when pressed. Doesn't sync with phone so can't change the clock face . Anyone any other ideas what to do?
09-06-2020 07:58
09-06-2020 07:58
Mine only lasted a year. ☹️
09-06-2020 10:13
09-06-2020 10:13
Mine didn't.. sucks no more fitbit for me
09-21-2020 12:02
09-21-2020 12:02
Don’t buy Fitbits. This is my second Fitbit and as soon as you pass the 1 year warranty they do and “update “ then your device stops working. When you call support the offer a discount on a new one. Complete scam. They should be ashamed of themselves.
09-21-2020 12:22
09-21-2020 12:22
10-05-2020 12:54
10-05-2020 12:54
This is what happened to me. I left my Fitbit in the drawer for a couple of months, pulled it out, and now I am stuck with a black screen / button that does nothing but cause device to vibrate. (Mind you this was a replacement for the first one which died within a couple of weeks of owning.) Support only offered a discount instead of a replacement as I am past the 1 year warranty. Hopefully Fitbit reaches the Google graveyard...they have at least lost me as a customer.
10-18-2020 17:28
10-18-2020 17:28
I am having this same problem with my Charge 3. Restart instructions dont work and the watch is not synching to my phone so I cant change the clock face.
10-20-2020 20:06
10-20-2020 20:06
I am having the same problem as @N1MU
what should i do ? @MarreFitbit
10-20-2020 20:09
10-20-2020 20:09
My Fitbit charge 3 is blank screen after reset and clock face change
10-21-2020 10:37
10-21-2020 10:37
Buy another brand...
11-08-2020 15:56
11-08-2020 15:56
Hi! I've tried to reset my fitbit charge 3 all day. It vibrates when the button is pushed but screen is black. It wont give me the smiley face no matter how many times I try or how long I hold the button, super sad! I also cannot change the clock screen because it just keeps saying that its trying but nothing pops up on my fitbit and it never says that it's done changing.... please help!!
11-08-2020 17:31
11-08-2020 17:31
