11-18-2020 10:54 - last edited on 12-24-2020 14:29 by LiliyaFitbit
I bought my Charge 3 at the start of August and this is the second time that I've experienced problems with it.
I'm very disappointed.
I noticed that my Fitbit wasn't synching so I unpaired the device with the intention of pairing again as this resolved the same issue a few weeks ago.
It hasn't worked this time.
I followed the advice to uninstall/ reinstall Fitbit, turned my phoned off /then back on, switched off my phone's Bluetooth / then on again/ checked that other local Bluetooth are turned off, but my Fitbit still does not work.
Neither the green LEDs on the back of my watch or the clock face are illuminated, but the watch still vibrates when I click it into its recharge cradle.
I carefully checked the charging connectors on the back of my watch and in the cradle to ensure they were clean and grime-free.
I have also checked the phone and Fitbit charging cables to ensure that they are in working order,
Still no change in the situation.
This is the first Fitbit I have owned and it has not been a good experience so far...
Does anyone have any other ideas?
11-18-2020 11:02
11-18-2020 11:02
I to am having the syncing problem. I have followed all the steps that the help steps have said and still my phone will not sync with my watch.
Best Answer11-18-2020 12:48
11-18-2020 12:48
Have you tried resetting the tracker? I don't see that in your list of things you have tried.
I have had trouble with connecting pairing and synching today and went through most of the steps you listed on iphone, Windows 10 PC and android phone with no success. Finally, I tried a reset of the tracker and it worked (on the second attempt).
For a reset,
- put the tracker on to charge
- press the button on the side in for around 8 seconds until a smiley face is displayed
- wait and see what happens
Good luck. I don't think there is anything more frustrating than trying to get a fitbit to sync.
Best Answer11-18-2020 13:29
11-18-2020 13:29
Best Answer11-18-2020 13:48
11-18-2020 13:48
Hi,
Thanks for your suggestion. It's still not working. I think I need to request a replacement or a refund tbh...
