Charge 3 white lines on the screen
ANSWERED
Hello.My fitbit charge 3 has white lines through the display.Ihave restarted several times and done a restart with my watch connected to the computer.Changing the clockface doesn't work as lines are on all display functions.thanks
1 BEST ANSWER
Accepted Solutions
@collette1137 I believe this is a hardware issue with the screen.  You should contact customer support using this link.  Best of luck!
Heather | Community Council | Eastern Shore, AL
3 REPLIES 3
Hi there @collette1137, welcome to the Community Forums. Thanks for the details provided about your Charge 3's screen and for taking the time to fix it prior to contacting us.
Since this sounds a bit more serious, I've created a support case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know.
Thanks for your recommendation @Heather-S.
Let me know if there's anything else I may do to help you.
Thankyou will do,
