07-15-2019
02:04
10:55
07-15-2019
02:04
10:55
My tracker will not stay charged at all. I can charge it in the morning and it will die while I’m sleeping at night. I’ve restarted it multiple times. I keep the screen brightness low. I’ve turned off all notifications. I’ve turned off all day sync.
How else can I resolve this?
07-16-2019 06:49
07-16-2019 06:49
Welcome on board @DallasRN! Thanks for all the steps you've tried so far in order to solve the issues with the short battery on your Charge 3.
I'd recommend restarting your Charge 3 one more time. Then, let your device to run out of battery to charge it again. Keep an eye on it to see how the battery goes. You can also see: Can I extend my Fitbit device's battery life?
If the battery keeps draining faster than expected, can you please let me know which clock face are you using? Also, try using a different one and monitor the battery life afterwards to see if the issue persists.
We recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all.
Tips to best charge Fitbit trackers are:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
Let me know how it goes, I'll be around.
07-16-2019 13:05
07-16-2019 13:05
Thank you for your reply! I actually tried switching my clock face yesterday from ‘mod clock date’ to ‘punctual’ and again, my charger was dead before I woke up (from a full charge that am)
I’ve only ever used the charging cord that came with my Fitbit and used a wall adapter (the one that came with my iPhone). I’ve never plugged it into anything other than the wall charger!
I will try resetting it again and letting it die all the way.
Thank you you so much for the help.. I really love my Fitbit! But this battery issue is disheartening.
07-18-2019 14:10
07-18-2019 14:10
Thanks for coming back and letting me know the outcome @DallasRN!
Since the battery is still draining, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to assist you with.
07-18-2019 22:52
07-18-2019 22:52
Thank you..
I reset it once more, let it drain all the way to dead. I charged it early this afternoon and the battery is empty before I’ve even gone to bed. 😞
I will watch my email.. thank you again.
07-19-2019 11:37
07-19-2019 11:37
Hi there @DallasRN! Thanks for restarting your Charge 3 once gain.
I'm sure that our Support Team will be outstanding with your case. Please keep an eye on your inbox, someone will be in touch with you soon.
I'll be around if you need anything else.
08-06-2019 03:07
08-06-2019 03:07
Over the last two weeks I have watched the battery on my Fitbit Charge 3 not being able to hold a charge for more than 48 hours. Yesterday I charged it to 100% and this morning it's down to 10% without me wearing it at night.
I have shut it down multiple times, changed clock faces and charged it only on USB with the cable that it came with. It is less than 8 months old. What other options to I have to make it work?
09-25-2019 05:04
09-25-2019 05:04
So how do I restart my charge 3? Mine hasn't gotten to where it won't hold a charge at all yet, but it has gotten to where the charge only lasts a day or two now instead of a week like it did when I purchased it back in February 2019. I don't put it on to charge until I see the low battery face.
09-25-2019 05:18
09-25-2019 05:18
09-27-2019 08:24
09-27-2019 08:24
Hi there @1jamorty2019, welcome to the Community Forums. I'm sorry for the late response.
Thanks for the details provided about your Charge 3's battery life. I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Hey there @stacaroo73, it's nice to see you here! I'm glad to hear that our team replaced your Charge 3. I hope you're enjoying your new device.
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted! 😉
03-10-2020 04:22
03-10-2020 04:22
I am having the same problem. My Fitbit went from staying charged to 4-5 days to only holding a charge for less than 24 hours in less than a week. Last night I charged it to full battery via the charger that came with my Fitbit in a USB port, and it was 15% when I woke up 7 hours later!! I've tried restarting it, but I need a solution bc it's affecting me at work to not have a clock on my wrist
03-11-2020 04:21
03-11-2020 04:21
05-11-2020 15:44
05-11-2020 15:44
I am having the same issues. My Fitbit Charge 3 won't keep a charge at all. It dies immediately after I remove it from the charging cable after charging it completely. I've only had mine for about 16 months. Please help!
05-12-2020 04:44
05-12-2020 04:44
06-26-2020 13:04
06-26-2020 13:04
We are having the same issue. We are using the same charging cord that came with the Fitbit, changed the sync time and clock face. It will not stay charged for 12 hours.
06-26-2020 13:21
06-26-2020 13:21
06-26-2020 13:36
06-26-2020 13:36
I'm on my 3rd Charge 3 in about 15 months. I bought my first in March 2019, and in August 2019 the screen stopped working, yet it would sync. I got a replacement on warranty that arrived in September, and that worked up until the end of April of this year, when it did the exact same thing again. I was able to get another under warranty, and now THIS replacement, after working fine for 5 weeks, now goes from 100% at 8am, to giving me battery warnings at 8pm, and will be dead by midnight. I don't know if I'm just having a really bad run of luck but I'm super unhappy with the devices that I've had 😞
06-26-2020 13:48
06-26-2020 13:48
08-24-2020 05:35
08-24-2020 05:35
Hi there! I am having a charging issue as well! My charge 3 will be at 100% and be dead within 2-4 hours. It is very frustrating as I rely heavily on it for time, dieting, and my sleep patterns. This issue has been going on since 7/31/20. It started out that my charge would randomly start a continuous vibration until I plugged it in or it died. That stop but then now it won’t stay charged. My husband took the bands off to ensure everything was clean. I work as it used to for an entire week. Lasted me 6 days this week. Now back to dying. I’m sad. I have only had it about a year and a half. Please help. Thank you.
