05-03-2019
01:47
11:08
05-03-2019
01:47
11:08
I downloaded the latest update and now my Fitbit won't charge. When I put it in the charger it doesn't connect and doesn't vibrate.
I've tried to restart it but it just changes to the screen wake/notifications settings screen. Can anyone help?
05-04-2019 07:26 - edited 06-21-2024 05:35
Welcome on board @Amanda10, it's nice to see you around here! Thanks for trying to restart your Charge 3 in order to the battery issues. Nice way to go!
Please take a look at the help article Why isn't my battery charging? and follow the instructions provide there.
We recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all.
Tips to best charge Fitbit trackers are:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
Let me know if you need anything else.
05-05-2019 14:13
05-05-2019 14:13
05-06-2019 08:53 - edited 06-21-2024 05:35
Hi there @Amanda10, thanks for coming back and for sharing the outcome of the recommendations provided.
If your device is not vibrating or restarting, from the clock face, swipe to Settings and tap Reboot Device.
Then once again, follow the restart instructions below.
Let me know if your Charge 3 can vibrate and be restarted after the reboot.
I'll be here, keep me in the loop.
05-22-2019 20:29
05-22-2019 20:29
I am having the same problem. When I place the Fitbit in the charging cradle it does not vibrate or charge. I have tried the charging cable in different charging plugs (nothing happens). I have cleaned the connections as recommend (with alcohol wipe), rebooted the device, and then tried to do reboot with the Fitbit in the cradle and still nothing. When I tried to reboot in the cradle I don’t get a smiley face, or a vibration, the screen just turns off.
what is the solution? I’m ready to toss this piece of junk and buy an Apple Watch. Plus I really don’t want to call customer service and speak to someone on a bad long distance connection.
05-22-2019 21:08
05-22-2019 21:08
05-23-2019 06:15
05-23-2019 06:15
I have two fitbit charge 3s and two chargers. The non charging Fitbit does not work in either charger
05-23-2019 07:29 - edited 06-21-2024 05:35
Welcome to the Community Forums @Hotdax! Thanks for following the tips and recommendations provided above and for trying with a different charging cable.
Since the steps you've tried did not work, I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Hey there @Amanda10! We're glad to hear that you're back on track after getting a new charging cable.
Please let me know if there's anything else I may do to assist you both.
07-30-2020 06:22
07-30-2020 06:22
I update my Fitbit and it was working fine after the update. I plugged it in to charge overnight and it now is just a black screen. Won’t charge, doesn’t vibrate or even appear to be getting anything from charger. I cleaned everything, tried different outlets and directly into usb - nothing.
seriously might just go buy the new Apple 5 it is so frustrating and wait times for customer service are ridiculously long 😕
07-30-2020 15:15
07-30-2020 15:15
09-03-2020 15:00
09-03-2020 15:00
I have the exact same issue had my charge 3 and my wife has a charge 3 as well her battery dies in two days and mine was working fine until the update and now does not work at all.
Tried cleaning and using more than one charging source and more than one charging cable. Wifes will charge mine wont.
