06-03-2019
11:55
10:58
06-03-2019
11:55
10:58
My Charge 3 recently started taking super long to charge to 100%. I will plug it into charge when the battery low warning appears. It charges super fast up to 99% then takes more than 2 hours to charge to 100%. That last 1% recently started taking very long. When I first got this Fitbit it would charge to 100% in 2 hours max. Can someone help?
06-04-2019
06:12
10:17
06-04-2019
06:12
10:17
It's great to see you around @Ren_Ren90.
If your Charge 3 isn't charging properly, I recommend taking a look at the help article: Why isn't my battery charging on my Fitbit device? and follow the instructions provided there.
Let me know the outcome. ![]()
06:59
05:37
AlejandraFitbit
04-17-2020
06:59
05:37
AlejandraFitbit
This was not a helpful solution. I have the same problem. The link provided is about trackers that aren't charging. The problem is the trackers are only charging to 99%. Why is this happening?
Moderator edit: format
04-20-2020
05:39
10:17
04-20-2020
05:39
10:17
Welcome to the Forums, @Jamie_627.
Sorry for the delay in response, due to recent events affecting our operations, support options are limited and wait times are longer than usual.
About your battery issue, have you tried the instructions provided in the previous link? If you haven't, please follow them and see if by following those steps your tracker gets to charge to 100%.
Keep me updated.
Best Answer06-25-2020 13:39 - edited 06-25-2020 13:39
I have been having this issue for months. No matter how long it stays on chargers, it shows 99%. I tried to reboot it, which the article above suggested, yet still same issue.
09-12-2020 00:19
09-12-2020 00:19
The commenter literally said those directions don't work. I've had a Charge 3 for a while, and for the last year I've had this problem. Nothing helps. I have rebooted it 3 times in one charging session and it STILL won't charge to 100%.
